E36 (1991 - 1999)
Old 09-20-2012, 03:26 PM
Jamie h Jamie h is offline
Mein Auto: 1998 bmw 328i
Post transmission problem
I have a 1998 328i with automatic transmission..basically wont shift out of 1st, but sometimes in 2nd with encourgement, no 3rd. tried in auto and manual...no codes.....any ideals I could try...fluid is fine...
thank you for ant help..
jamie
Old 09-20-2012, 03:35 PM
Dino1394's Avatar
Dino1394 Dino1394 is online now
bimmerfest Supporting Member
Mein Auto: 04 330xi
I dont know much with the auto trans but I think yours may be shot.
How many miles on it?
Old 09-20-2012, 03:38 PM
150,000..wouldnt it show some codes
Old 09-20-2012, 03:48 PM
Dino1394's Avatar
Mein Auto: 04 330xi
Not necessarily, You said the fluid was fine, Was it changed at all?
Old 09-20-2012, 04:00 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '96 328iC, '04 325Ci
There are only a few faults in the auto tranny that will generate the transmission failure light on your dash. There are more codes however that are stored in the transmission computer that will not show up on the OBDII data port connector. The dealer and some indie shops have the code reader for the transmission. By the way, the transmission is supposed to not shift when you select the M position. That position tells the tranny to stay in the gear you have selected.
'96 328iC "Marie"
Old 09-20-2012, 04:26 PM
you are correct on the manual part, ok in first in manual and 2nd also with some encourgement and no 3rd in manual just like when in auto..anything else you could suggest...
thank you
Old 09-20-2012, 04:32 PM
Dino1394's Avatar
Mein Auto: 04 330xi
Try driving without manual at all
Old 09-20-2012, 07:05 PM
Cipher_tx's Avatar
Cipher_tx Cipher_tx is offline
Mein Auto: '93 325i sedan
'Fluid is fine'. How fine? Is it bright red? Are you checking it hot with the engine running?
Could be a blockage in the valve body. Chances are that the tranny is gone.
Old 09-20-2012, 11:08 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Dude, that transmission is knackered.
Sent from my MB860 using Bimmer App
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 11-27-2012, 06:04 AM
josephroberts75 josephroberts75 is offline
Mein Auto: e36 bmw
clutch packs are shot!!!!!
