Old 09-21-2012, 07:42 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Want a decent Fluid Pump
Does anyone own a Mityvac MV6400? I want one specifically for filling transmission and differential oil. It doesn't really need to do anything else.
I am getting older and more and more tired of cheap, messy fluid pumps and I would like something nicer and more fun to use.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 09-21-2012, 07:45 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
How much are they?
Looks nice.
Randy made his own, using a normal jug. He just watches the aboutit bulges to control the pressure.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 09-21-2012, 07:54 AM
JonM's Avatar
Moderator
$133 from Amazon I guess.
I am curious if a regular garden pressure sprayer with a modified hose could do it, albeit very slowly.
Jon Maddux
Old 09-21-2012, 08:00 AM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Go to NAPA. You can get a pump for under $10 and they work great. I got mine from Amsoil. It screws right on the bottle and goes right back in the small box when done. Don't drop over a hundred on something that will do the job better for 10.
To see what I am talking about, scroll to the bottom of this page.
https://www.amsoil.com/a/synthetic-gear-oil
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
Old 09-21-2012, 08:07 AM
awdonald awdonald is offline
Mein Auto: 00 z3 m coupe
Thet famous store for fine tools...Harbor Freight...sells a hand pump thar will "suck and blow" for about $5
Old 09-21-2012, 10:33 AM
JonM's Avatar
Moderator
I have used various ~$10 hand / transfer pumps for years and I am not pleased with them. Want something better.
Jon Maddux
Old 09-21-2012, 05:59 PM
brock5ga brock5ga is offline
Mein Auto: Z4
That's what I did at the shop. I bought a $10 sprayer from Home Depot, unscrewed the spray adjuster tip, and took a piece of fuel hose and screwed it on the end and secured it with a tie strap. Works fine for ATF and Manual Trans Fluids. We have drums for the gear oil for the diff. so I haven't tried that. It is a little slow, but we don't have the need for it a lot. I looked at the Mityvac, but determined that I would purchase one when I saw I was using my sprayer enough to justify the purchase. The sprayer has been in use for over a year now in a shop environment and still holding up.
Old 09-21-2012, 06:40 PM
Randy Forbes's Avatar
Investigative Tinkerer
I bought that exact model, likely off Amazon, just before leaving Ohio. I used it for the first time one (1) week ago today, putting some coolant into Sue's decorator's Land Rover. It worked great for that, but like you, I wanted if for the differentials (that I have to refill while on the car) and xmsns.
The plastic jug is substantial, the fittings look to be of decent quality and the hose is slinky-slinky__NOT stiff at all. I'd say it wins on all marks.
Originally Posted by Pinecone View Post
How much are they?
Looks nice.
Randy made his own, using a normal jug. He just watches the amount it bulges to control the pressure.
I just felt that one day, I'd crank that regulator handle a quarter turn the wrong way, and have a hell of a mess to clean up...
Edit: I'm thinking that I paid waaay less than $133.00 for it though, and that's probably "why" I bought it before moving, instead of having one (1) less thing to pack and move; it must've been on sale.
Randy Forbes
2001///M Rdstr Steel Gray
Old 09-22-2012, 10:15 AM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
I use the Sta-Lube fluid pump http://www.crcindustries.com/ei/cont...aspx?PN=SL4344
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 09-22-2012, 11:29 AM
Those pumps are okay, depending on how often you need to use them, but for filling up a trans, that's A LOT of pumping (while holding the bottle in your other hand).
Depending on the value of your time (remember, Jon's an aerospace engineer) the cost of a premium fluid transfer pump that's made for years of severe service, really isn't so bad.
Randy Forbes
Old 09-23-2012, 04:17 AM
Pinecone's Avatar
M Mad
I agree, but I would want two, and close to $300 is a LOT of pumping.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 09-23-2012, 07:05 AM
coopers coopers is offline
Mein Auto: 2001 Z3 2.5i
What is used to clean or flush a pump, when switching transmission fluid and diff oil?
Old 09-23-2012, 10:49 AM
JonM's Avatar
Moderator
Alternative with slightly better price....
http://www.ecstuning.com/BMW-Z3-M_Co...ain/ES2207920/
Jon Maddux
Old 09-30-2012, 02:07 PM
Mein Auto: Z4
http://www.tooltopia.com/lincoln-lubrication-615.aspx
Didn't really think of this until I serviced the trans the other day. I use this for manual trans fills and rear ends that we aren't using bulk gear oil in. Just hang upside down over a drain bucket after using and gravity will take care of the residual fluid for you. The one from ECS does look like a nice alternative to the MityVac. Just might break down and purchase one for use at the shop. Just thought of this other affordable, low mess option.
