E46 (1999 - 2006)
Old 09-21-2012, 12:55 PM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
What to replace while exhaust and driveshaft are off?
My flex disc/guibo is starting to go. No vibrations or clunks, but it's squishy to the touch and I can see the edges are starting to fray, so it's time to replace. I also have a small tranny leak that I'm pretty sure is coming from the selector rod seal (I hope!), so that's going to get replaced while the drive shaft is out of the way.
I like to be proactive on maintenance, so if there are other things that I can replace while the exhaust and drive shaft are off, I like to get as much stuff out of the way as I can. So, at 125k miles, what else should be done?
I think my center support bearing is fine, but should it be swapped as long as I'm under there?
Same thing with tranny mounts -- should I just swap them while I have access?
Shifter rod joint?
Anything else?
Old 09-21-2012, 01:19 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
I'd do the tranny mounts... easy and inexpensive. Go with something like Rogue Engineering or whatever else is popular in the aftermarket these days (other than UUC). Firming these up actually helps smooth out shifts. I've had RE in mine since the car was new.
Anything you can reach that's cheap... why not?
Jeff R.
Old 09-21-2012, 01:42 PM
Scottji's Avatar
You think RE over the M3 tranny mounts? The M3 mounts are only $14/ea and are supposed to be an upgrade. Looks like RE are $55 for the pair.
My thoughts exactly.
Old 09-21-2012, 02:15 PM
jvr826's Avatar
Is it Trackday yet?
I'd pass...
Non-M
M3
Rogue Engineering
'nuff said?
Jeff R.
Old 09-21-2012, 02:45 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Center driveshaft carrier bearing
Old 09-21-2012, 03:19 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
This^^^^^
Old 09-21-2012, 04:38 PM
Scottji's Avatar
Does the center support bearing really fail? If I got the diff bushing and guibo before they failed (which I think I have), shouldn't the center support bearing be fine?
Old 09-21-2012, 04:43 PM
smolck's Avatar
ROLL TIDE!
Bearings wear over time like anything else. You might be fine, but wouldn't you be pretty po'd if it did fail considering it is about $39? I have seen them fail, it ain't pretty.
http://www.oembimmerparts.com/produc...501257ae46.htm
Old 09-21-2012, 05:22 PM
SJBimmer's Avatar
Yup. and if it fails at high speed, you WILL be buying a new driveshaft, and, it might just take your nuts off. Sounds like a deal at $40 now, doesn't it? In all seriousness you don't want to do this job twice to save just a little bit of cash. Been there, done that. I learned my lesson a long time ago.
Old 09-21-2012, 06:09 PM
CRJ900 CRJ900 is offline
70 428 SCJ, 04 325xi
Mein Auto: 2004 325xi
Why do you think your flex disc/guibo is starting to go? you say it does not vibrate, and no chunks are missing, but you think it is squishy to the touch. Is it bad or not? I do not understand the logic of replacing parts that are not bad. Approach this like a Mechanic and not a enthusiast. Is it bad or not? I am not against preventative maintenance, but seriously, how deep is your wallet? are you throwing money at the car just because something you read on an internet forum told you to? Kinda like the '99-2000 cars had reverse problems, but later models did not. But if you read the forums, all BMW 3 series cars have reverse issues and always will
Old 09-21-2012, 06:36 PM
smolck's Avatar
ROLL TIDE!
You are an idiot. I've worked on more E46's than I can count and there is a LOT of maintenance items that need to be replaced BEFORE they fail. Guibos are the link between the driveshaft and trans output shaft, they take a ton of abuse and over time wear out. Believe it or not.
I don't wait till my car overheats to tell me I need a new cooling system either. Easier to replace it on MY terms than on its own terms.
Old 09-21-2012, 06:42 PM
Scottji's Avatar
Ha, when you put it like that, hard to argue. Added to the list, thanks for the education.
Old 09-21-2012, 06:44 PM
Scottji's Avatar
Besides being soft to the touch, it is missing parts/sort of frayed around the edges. It feels like I could rip chunks off with my bare hands. Definitely compromised and time to replace.
Old 09-21-2012, 06:57 PM
Well, since we have the exhaust out, why not replace that. Or, lets replace the drive shaft, exhaust manifolds, heads, block, etc etc etc. I've been a mechanic for 30 years, and one thing a good mechanic does is diagnose when it is the proper time to replace a part or not.
Internet forums can be a wealth of info, and also cesspool of garbage. The OP asked what other items he should throw money at while he is in there, and seriously most of the recommendations where regurgitated internet crap.
Calling me an idiot is pretty harsh, don't ya think? this is my opinion and you don't know me personally
Old 09-21-2012, 07:18 PM
Scottji's Avatar
PM me your address and when I get my guibo out I'll send to you for inspection. If you determine it's in good shape I will come on here and tell everyone you were right.
Old 09-21-2012, 07:56 PM
Your missing my point. Your original post stated " No vibrations or clunks, but it's squishy to the touch and I can see the edges are starting to fray" what are you using as a reference to determine your flex disc/guibo is starting to go? It's your money, but answer honestly, are you replacing it because it's bad, or are you replacing it for the hell of it? If you want to replace it go ahead. If you are serious, I will PM you and you can send me the flex disc, if it's good I'll put it in my spare parts supply.
Old 09-21-2012, 08:38 PM
smolck's Avatar
ROLL TIDE!
Ah yes, Like your posts.
Old 09-21-2012, 08:59 PM
Scottji's Avatar
Well, you know what they say about arguing on the internet.
I think the issue is that I was under my car recently, I looked at the undercarriage with a flashlight like I do every time I change my oil, and I felt my flex disc with my hand and inspected it visually, along with a host of other things. I just went back into my garage and pulled a chunk of flex disc off with my hand -- I'm pretty sure that shouldn't happen. You were not under my car yesterday (at least not that I know of ). I have not been a mechanic for 30 years, like you have, and no doubt you know more about cars than me. But at least give me the benefit of the doubt on this one. I know what the rubber bits should feel like and look like, and this thing is on its way out. Could I get another 5k-10k miles out of it before something catastrophic happens? Maybe, but since it's failing, might as well take care of it now rather than wait until it fails and places additional stress on other bushings/mounts/bearings. That's my thought, anyway.
Old 09-22-2012, 10:46 AM
SJBimmer's Avatar
I agree that calling you an idiot is a little harsh, but I would also not call you a mechanic. This is the part we are referencing:
http://oembimmerparts.com/product_p/...454-410e46.htm
It costs $59. If I went to a shop and they told me that a critical rubber/fabric part of the drivetrain that has chunks missing was ok, or that it is ok for that part to be soft, I would walk out and tell all of my friends to avoid them like the plague. You may have been a mechanic for 30 years, but in this particular instance, you have no clue as to what you are talking about. We don't appreciate poor advice around here, and what you are offering is poor and irresponsible advice. What we offered is backed by years of experience and personal knowledge with these cars. I would seriously suggest going back to Lincoln Tech for a refresher course.
Old 09-22-2012, 11:14 AM
SJBimmer's Avatar
No problem! Don't forget to put reference marks on everything, so that it goes back in exactly as it came out, and install the guibo in the correct orientation. You don't want anything to be out of phase, and have to tear it all apart again.
Old 09-22-2012, 12:39 PM
chansta chansta is offline
Learning Daily
Mein Auto: 89 CIVIC
if you can pull a big chunk off of it with your hands your car would have done that long before you even inspected the flex disc.
CRJ900 theres no point in trying in this forum. there are a certain number of people who consider themselves master "DIY" and think they have nothing to learn from people who do this for a living as a professional. and these individuals have hundreds of followers who swallow their inexperienced diy information because of their forum post count.
iATN
Old 09-22-2012, 02:04 PM
catso's Avatar
catso catso is offline
catso
At about 123,00 miles my guibo was toast, took everything apart and of course removed and replaced the center bearing. It looked as good as new, but for the money, it seemed foolish not to replace it. Afterwards, the driveline was instantly MUCH smoother. Buy only quality parts and you will probably never need to replace either again.
![/I][/FONT]
Old 09-22-2012, 02:30 PM
Scottji's Avatar
Um, well obviously the car didn't take it off, since I just pulled a piece of it off by hand.
Old 09-22-2012, 02:47 PM
chansta, you are very correct. I understand as a BMW enthusiast and owner we tend to go above and beyond when it comes to taking care of our cars. I understand I may have ruffled some feathers with my posts.
And SJBimmer, what exactly makes you an expert on the subject? So you don't think I am a Mechanic. Fine, thats your opinion. But it's important you understand the difference between a parts changer and Mechanic. I am just offering an alternative point of view. What a real Mechanic does is determine the serviceability of a part. And the responses the OP got back were pretty much, "well, I did this on my car so you should to, and hell, why your in there replace this, this, etc"
This thread reminds me of the one guy that questioned 7000 mile oil changes. Nobody could offer any evidence as to why 15000 mile oil had to be changed at 7000 miles. The only answer in a nutshell, was that everyone thought it had to be changed sooner just because. Never mind what those engineers say.
Old 09-22-2012, 04:17 PM
SJBimmer's Avatar
What makes me an expert is my mechanical engineering degree, and the fact that I posses common sense. The serviceability of the part has been determined. There are chunks missing, the rubber is soft, and the edges of the part of fraying. My friend works at a BMW dealership and this is a common failure item at around 100K in our area. It may fail sooner if the car is in an area of high heat, or if the car has been aggressively driven. I will no longer respond to any of your posts, because I am getting the impression that you are a troll. I also retract my statement that calling you an idiot was a little harsh. Judging by your ludicrous statements in your last post, it is clearly apparent that you are. Apparently, the public school system in Minnesota has failed you, because your comprehension skills are nonexistent.
