Old 06-06-2012, 09:36 PM
Z4Black Z4Black is offline
H. Ebel
Mein Auto: Z4 30i
Swerving 2005 Z4
I just purchased a 2005 Z4 with 37,000 miles and not sure if the tires have ever been updated. The right rear was replaced recently though due to a flat. The tread on the left rear still looks pretty good. The front two tires are worn on the outer edges but have less tread on the outside. The car seems to swerve more than it should especially when I'm on a rough highway with groves from heavy trafic. Is that common due because of the smaller wheel base. I noticed this just outside of Vancouver WA. As the roads got better the problem seemed to go away. Any thoughts?
Old 06-07-2012, 06:01 AM
jparnes1 jparnes1 is offline
Mein Auto: 2011 Z4 35i, 2006 525xi
This is the E89 forum for Z4's 2009-. Try the E85 forum.
2006 525 xi, Orient Blue Metallic, Beige leather, Dark Poplar trim, Premium Package, Cold Weather Package
2012 Z4 35i, ED 2/24/12, Melbourne Red Metallic, Black leather, 6 MT, ///M Sport, Premium Package, Premium Sound Package, Cold Weather Package, Nav, Comfort Access, LED Angel Eyes, BMWPedals pedal covers, stubby antenna, Luxon strut bar, CF engine cover, LCI side marker, powder coated calipers, Extra Enjoyment Package
Old 06-07-2012, 06:25 AM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
Wrong forum, but tires should never be replaced singly.
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
Old 06-07-2012, 09:59 AM
mrMTB mrMTB is offline
Certified Car Nut
Mein Auto: e92 M3
Agree. Replace the other tires and get a quality alignment. It'll make a world of difference.
Old 06-07-2012, 10:22 PM
Terry J. Harris's Avatar
Terry J. Harris Terry J. Harris is offline
bimmerfest Supporting Member
Mein Auto: '05 Z4 3.0i & '08 X3.0si
Z4Black - you posted in the correct forum. The posters above experienced excessive tramlining and wound up jumping lanes/forums back to the past . . . .
Old 06-07-2012, 10:41 PM
Old 06-08-2012, 04:55 AM
Stromtech Stromtech is offline
Mein Auto: 2004 Z4 3.0 6 speed
Sounds like the infamous tramlining
Are they all Run Flat Tires?
If they are the original 2005 tires then they are past their sell by date so consider ditching the run flats.
Are all the pressures correct?
When was an alignment last done?
I ditched the run flats recently and it made the world of difference, no more tramlining. I had an alignment done yesterday and it tracks like a new car. (04 3.0i)
Old 06-08-2012, 07:10 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Tramlining can occur with worn tires, certain tires when new, when certain alignment settings are off, and some cars are more prone to it that others.
But I agree with previous posters, I am not big fan of replacing a single tire.
With the worn fronts, I would serious consider new tires all around and a check of the alignment by a good shop.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 10-03-2012, 02:30 PM
H. Ebel
Mein Auto: Z4 30i
Hi, thanks for all the advice and sorry for the long delay in my reply. I ended up replacing all 4 tires with Toyo Proxes 4+ (All Seasons). The ride is much better and I haven't been experiencing the swerving I did before. I also did the recommended front end alignment and installed new ceramic brakes so I sure that helped as well.
H. Ebel
Old 10-03-2012, 08:21 PM
4dimnzn 4dimnzn is offline
Mein Auto: 2002 M Coupe 2006 M Roads
I understand that in Washington all season tires may be a smart choice. If your budget allows it, next spring snag some summmer high performance tires (Michelin Super Sports are on mine) and take your car to the next level.
Old 10-03-2012, 08:43 PM
H. Ebel
Mein Auto: Z4 30i
I know...I went back and forth between the All Season and the Sport tires...maybe next season!
H. Ebel
