The X5 SAV Forum
Old 09-22-2012, 01:46 PM
tbreedlove tbreedlove is offline
Mein Auto: 4.1 x5 sport
Question diagnosis help needed- transmission, fuel pump??
Hi, I have a 2005 4.1 sport x5 with 35,000 miles on it. It is doing two odd things when driving.
1. When i am driving at a speed right below 40 miles per hour or when it is in 5th gear it drives as if it is chugging ( almost as if I am consistently partially pressing and releasing the breaks). It doesn't always do this but is pretty consistent.
2. Occasionally when I start to accelerate from being stopped it slams as if someone has rear-ended me. This has randomly happened 3 times within the last month.
I would like to think that it isn't a transmission issue considering how low of mileage it has..
Any thoughts as to what this could be? I haven't taken it into a mechanic yet. This is my second BMW the first was a 2003 325i with 120,000 miles.. had the same issues.
Old 09-22-2012, 01:49 PM
Also, there isn't a check engine light on
Old 09-22-2012, 07:30 PM
Gurjit Gurjit is offline
Mein Auto: 2004 4.8is
hows it drive in Manual mode?
Old 09-22-2012, 07:32 PM
It does the chugging while running in 5th but shifts and runs fine in all the other gears
Old 09-24-2012, 01:43 AM
still has top end power?
spark plugs been changed?
Old 10-31-2012, 02:54 PM
cj_lovely7 cj_lovely7 is offline
Mein Auto: X5 4.8is
i have a 2004 BMW x5 and have recently had a new fuel pump put in since then I have noticed a sluggish start to my ride. This is noticed when Im taking off from a stop..like a stop light..it takes awhile to get going and build up speed. This is very obvious going up hills as well. You had mentioned spark plugs, could this be a cause of my issue as well. What should i be looking at as far as price if so?..Thanks
