E34 (1989 - 1995)
Old 09-21-2012, 04:58 PM
Peter's 525I Peter's 525I is offline
Mein Auto: 95 e34 525i
grrrrr. car wont start
chnged the fuel filter and rad sensor, the one on the bottle today.
grrr car wont turn over!!
please help.
1995 e34 525i
M50 Auto K&N Sport Air Intake
THE TACK TACK TACK IS GOOOOOOOOONE!!!!!!!!!!! It's Like a new car!!!!!
Old 09-21-2012, 05:05 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
whatever it is, its unrelated to what you just changed, so you must have knocked something. This is impossible to diagnose on the internet, please read the "must read" sticky
E30 above Sold
Last updated 2nd January 2014
Old 09-21-2012, 06:56 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
If all lights on the dash come on as usual and nothing happens when the key is turned, it could be a couple of things.
One is, it could be the neutral safety switch. Try putting the transmission in neutral (assuming you have an auto transmission). I think the Bentley manual indicates how to check the stitch itself.
A second option (which is much less desireable) is that the EWSII may be faulty. The EWS is a security system that, when activiated, will not allow the car to turn over. I had to bypass mine on my E36, but the EWS module itself wasn't bad, my DME was.
Another thing to try is see if the secondary key will work. It is possible that the chip in the key may have failed and is not sending the signal to the EWS system.
Hope these suggestions help.
Most problems are usually something simple !
Originally Posted by noego View Post
It's Deja Poo - as in, I've heard this **** before.
Steve
Calypso Red 1992 525i with 225K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-21-2012, 10:21 PM
a little more info...
when the key is in the ignition the radio wont turn on and the windows wont open close.
1995 e34 525i
Old 09-21-2012, 11:57 PM
have you disconnected the battery??????
if not...
sounds like the starter motor is shot. this has an unloader curcuit in it that grounds certain in car electronics to take thier load off the battery while starting. open the engine bay as you turn the car to on and listen for a wirring noise which will then stop. then turn the key, do you hear a click or just nothing at all?
E30 above Sold
Old 09-22-2012, 12:25 AM
BMWFatherFigure's Avatar
Old School
Wouid this be another version of the oxide on the switch terminals that E38 are prone to? If so 1) Switch out 2) wash with switch cleaner while turning the it through its operating range. 3) Refit and reconnect.
Current:
E38 Parts Car
Previous:
Old 09-22-2012, 04:29 AM
duhhhhh. i fell like such a bird. Positive battery terminal not tightened all the way.she purrs fine. thanks for all your suggestions and help.
1995 e34 525i
Old 09-22-2012, 07:17 AM
BMR_LVR's Avatar
Humble E34 lover
Glad it was something so simple
It reminds us all to keep with the KISS principle when diagnosing a problem
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-22-2012, 08:53 PM
My525iT My525iT is offline
Mein Auto: 92 525iT Wagon M50
Happens to me all of the time on the project car.
P.S. is the fuel filter on the right way Aacckk
