Old 09-23-2012, 09:39 AM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
Did the tuner-mod the other day...
Had sum rare free time...so I did the Tuner Mod based on the instructions found here: http://www.bimmerfest.com/forums/sho...d.php?t=245819
You only use "C" "D" and "E" ..."E" is a ground, so U can use any spot in the car to ground it. Im not 100% certain why the OP had 5 wires listed.
Works as advertised
Next up is the L7. The Tuner mod can be done by a first timer...Please dont try it with the L7. There are people out there who specialize in repairing them at a good price.
Anywayz, The sub channels are out. I took a peek inside and would not suggest the repair if you havent done work in this field. Im not sure if this is outside of my soldering skills...we shall see.
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 09-23-2012, 11:12 AM
jkidem's Avatar
jkidem jkidem is offline
Mein Auto: 745Li
which cable a good one to use?
http://www.amazon.com/Cables-Unlimit...8423937&sr=1-2
or
http://www.amazon.com/Cables-Unlimit...8423937&sr=1-7
2013 328i M Sportline
2003 745li sold
2000 528i sold
Old 09-23-2012, 11:25 AM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Works as advertised
Great job , good for you . Now you get to
Enjoy your music off your phone or whatever
Other device you decide to use .
Sent from my GT-N7000 using Bimmer App
Old 09-23-2012, 12:15 PM
SideShow activist
Mein Auto: 745Li
cut one end off to solder the wires within.
Thank you
Current Lineup:
Old 09-24-2012, 04:39 PM
jkidem's Avatar
Mein Auto: 745Li
hey got mine back from the solder guy, i hooked it up to cheap headphones i cut till my 15 foot wire gets here but its so low with car volume turned all way its like i got the volume on 1 any ideas? could it be the cheap headphone wires i use they were ear bud headphones.....
2003 745li sold
2000 528i sold
Old 09-24-2012, 04:43 PM
collins912's Avatar
collins912 collins912 is offline
Mein Auto: 745i; 750Li; Yukon Denali
Old 09-24-2012, 05:15 PM
jkidem's Avatar
Mein Auto: 745Li
is the thumbs up to me? for the headphone cord i used?
2003 745li sold
2000 528i sold
Old 09-24-2012, 07:32 PM
SideShow activist
Mein Auto: 745Li
I dont understand.... you hooked headphones into your Tuner box?
That line is an Input. '
or, Maybe im not understanding, can u post a pic?
Current Lineup:
Old 09-24-2012, 07:48 PM
jkidem's Avatar
Mein Auto: 745Li
I cut the earbuds off
http://images.highspeedbackbone.net/...-vendor-sp.jpg
, this was just for a test to see if it worked cause my cable wont be here till tomorrow, but since i posted i went and messed with it again i think its the headphone cables cause i took them apart and touched wires and it came on like it should. So once i get cable tomorrow i think it will be good. thanks for your help
2003 745li sold
2000 528i sold
Old 09-25-2012, 12:34 PM
jkidem's Avatar
Mein Auto: 745Li
WOOT the mod is working great now with the stereo cable i got ) i even think the P3 subs are hitting harder hahaha thanks girl!
2003 745li sold
2000 528i sold
Old 09-25-2012, 02:18 PM
SideShow activist
Mein Auto: 745Li
AWESOME!!!!! Glad I could assist
Current Lineup:
Old 09-25-2012, 06:34 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
How easy is it to take part the plastic pillar by the rear glass? Does it just pop off?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 09-25-2012, 06:36 PM
jkidem's Avatar
Mein Auto: 745Li
yep all you do is pop of the HPC plastic button looking cover screw behind it take that out and it all pops out easy!
2003 745li sold
2000 528i sold
Old 09-28-2012, 12:24 PM
pmpn8ez's Avatar
I attempted this mod. Got it working within the first 30 minutes. My stupid self redid the solder and accidently pulled passenger side soldering point off. I tried to retrace the board but no luck. So now the radio only plays on driver side. I have a new radio tuner replacement on the way. I got a lot of practice on the old board. Hopefully I won't mess up the new one.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 09-28-2012, 12:25 PM
pmpn8ez's Avatar
In this pix looks like other solder points were used then the other ones indicated from the original thread. Or am I just looking at it wrong?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 09-28-2012, 02:25 PM
SideShow activist
Mein Auto: 745Li
I'll pull the rear panels off and get another (Better ) pic tonight.
Current Lineup:
Old 09-28-2012, 04:27 PM
pmpn8ez's Avatar
You don't have to go through all that. Did you use the same soldering points on the board as indicated in this pix?
On your pix looks like one off the channels is connected to a different spot on the board.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 09-28-2012, 07:48 PM
SideShow activist
Mein Auto: 745Li
Just use C,D and E...if you dont want to use E, ground it to the chassis
u can do the revers side if you want to trace the board but the pictured way is the easiest. ...there are multiple points
Current Lineup:
Old 09-29-2012, 03:06 AM
pmpn8ez's Avatar
Do you know other points on the board that I can use for this mod to work?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 09-29-2012, 05:14 AM
quarterto8's Avatar
quarterto8 quarterto8 is offline
Send a message via MSN to quarterto8 Send a message via Yahoo to quarterto8
Mein Auto: 2004 bmw 745i
What does this mod do?
2004 BMW 745I (SOLD)
2014 BMW 750LI
2008 BMW ALPINA B7
2016 JEEP GRAND CHEROKEE
Old 09-29-2012, 06:51 PM
SideShow activist
Mein Auto: 745Li
It gives you an Aux input.
When a signal is sensed, it cuts off the radio and will play whatever is being sent into it. Most of us are just using the earphone jack and playing music from any phone.
quick n dirty!
Current Lineup:
Old 09-30-2012, 10:20 PM
bmw74me bmw74me is offline
Mein Auto: 750i
quick n dirty!
Thank you for write up very much ,, would you know what are A and B for ..so basically don't wire them up ,and if so what are they
for ...thank
Old 10-01-2012, 03:22 AM
RTGrove RTGrove is offline
Mein Auto: 2006 750 Li
quick n dirty!
So fm radio will still work normally until you start playing something through the aux line in?? Any ghosting or overlap of signals? Is fm cut completely off when there is an aux signal?
2006 750 Li - His
2006 Volvo V70R - Hers
2002 Porsche 911 Cab - Her idea
1956 Ford Sunliner Convt - His idea
Old 10-01-2012, 03:34 AM
1bad540's Avatar
1bad540 1bad540 is offline
very cool.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 10-01-2012, 01:50 PM
pmpn8ez's Avatar
Just completed mine. First time around I ruined the passengers channel on the tuner in radio mode. Got a replacement for $150 and finished the mod in 20 minutes second attempt. Works perfectly.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
