Old 10-09-2012, 09:26 AM
los2much's Avatar
los2much los2much is offline
Mein Auto: 745li
anyone know how to do this on 2006 Audi a6 wagon with mmi ?
Old 10-10-2012, 06:04 AM
7Fif 7Fif is offline
Mein Auto: 06 750li Sport
Sweet Mod.
Old 10-10-2012, 05:42 PM
bkc0508 bkc0508 is offline
Mein Auto: 2006 750LI / 2012 2500HD
Did you have logic 7 and hd radio?
Old 10-10-2012, 05:55 PM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
Ive got the L7 Audio system but the tuner is the same...L7 or not.
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 10-10-2012, 06:12 PM
Oh thanks for the reply guess i will be doing the tuner mod this weekend since my plan to add factory aux did not work out. Did you split out your aux I want to do a normal aux cable and do a ipod cable.
Old 10-10-2012, 11:31 PM
los2much's Avatar
Mein Auto: 745li
if its logic 7 in the car then the tuner is the same right?
Old 10-12-2012, 05:01 PM
SideShow activist
Mein Auto: 745Li
yes, same tuner
Current Lineup:
Old 10-14-2012, 10:13 AM
los2much's Avatar
Mein Auto: 745li
fm signal is not canceling out when I plug in the aux
Old 10-14-2012, 10:33 AM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Did you soldered onto the right points? Is the AUX wire grounded properly? What cable are you using?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 10-14-2012, 05:56 PM
los2much's Avatar
Mein Auto: 745li
mouse cable and I didn't solder the points a friend did. Is there a fm wire I can cut cause I don't listen to the radio
Old 10-14-2012, 06:15 PM
pmpn8ez's Avatar
I would check the solder points. It should work like a charm. I should keep the radio function just for resale value. Once soldered on properly you could just leave an iPod connected and you would never have to listen to your radio.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-14-2012, 08:02 PM
jkidem's Avatar
jkidem jkidem is offline
Mein Auto: 745Li
Yeah something isnt soldered right it worked flawless for me
2013 328i M Sportline
2003 745li sold
2000 528i sold
Old 11-28-2012, 09:38 AM
los2much's Avatar
Mein Auto: 745li
Here is a pic of my soldering points so what look out of place?
Old 11-28-2012, 11:35 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
why does it seem like you have you separate wires being soldered onto the board? What kind of cable are you using?
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 11-28-2012, 12:16 PM
los2much's Avatar
Mein Auto: 745li
Mouse cable
Old 11-28-2012, 12:19 PM
Originally Posted by los2much View Post
Mouse cable
Why not just get an AUX cable an cut one end off? Driftgirl posted what she used and what solder points to solder to.
I think that maybe that's why your having issues with the FM not cutting out completely.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 11-28-2012, 01:43 PM
los2much's Avatar
Mein Auto: 745li
Sorry he used a head phone wire.
Old 11-28-2012, 04:05 PM
pmpn8ez's Avatar
RadioShack AUX cable works great. Male/female extension 16'. Cut the female end off and strip the wires to solder onto the correct points.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 11-28-2012, 05:44 PM
los2much's Avatar
Mein Auto: 745li
Thanks guy for the help. The points are so small how you know what is what
Old 11-28-2012, 06:06 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Sounds like you have a ground short with that small of a cable, you should get a shielded cable also.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 11-28-2012, 07:06 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
I could be wrong , But the way you did your wiring looks like the
style used when you need the switch that is used to toggle between
FM Radio & your Ipod or whatever your other source is .
Old 11-29-2012, 07:55 AM
+1.
I actually soldered a female side on the board, if I ever need to change out the AUX cable, I won't have to remove the board and re-solder.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 11-29-2012, 07:56 AM
This is a picture Drfitgirl posted earlier in the thread. I would ditch the mouse wire and get an AUX cable.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 11-29-2012, 09:16 AM
los2much's Avatar
Mein Auto: 745li
sound like maybe a bad ground from the other post i read that they changed the ground and it fix the noise or removed the 101 resistors
Old 05-26-2013, 08:20 PM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
Tuner Mod - OMG AMAZING SOUND!!
After many unsuccesful attempts to get decent sound (Tunelink, FM transmitter, etc etc) I decised to tackle the tuner mod.
One hour and 20 bucks later (plus 12 dollars for a fine tip soldering iron) I have true HD sound as good or better than CD.
For those on the fence about this mod, DO IT. So easy and cheap. There are plenty of good DIY's with pics etc. All you need is a 3.5mm aux cable which I got for 25 bucks (20ft) at Radio Shack, and a fine tip soldering iron. As stated above, it took me about an hour start to finish and that included running the cable up to the front of the vehicle via the door sills.
I could not believe the sound quality - no hissing, no static, no noise whatsoever. As soon as you plug your phone, ipod, or any other device, the radio switches to your source, REGARDLESS of whether you're on FM, AM and any channel. When you unplug, the radio is back on. Amazing. Wish I had done this long before now.
