Old 09-23-2012, 04:05 PM
D4T_POM's Avatar
D4T_POM D4T_POM is offline
Mein Auto: 2002 E66 745Li
Sunroof Leak
Hey guys My passanger side (UK Spec so passanger on left side) sunroof waqs leaking and now my passanger seat dont move back just front.
I dont know if its the drains thats clogged or if the seal is gone, as only the left side leaked and now my whole passanger floor is soaking wet.
Can someone help on as to what it can be i.e seat module?
also is my sunroof seal gone or the drain clogged?
Thanks in advance guys
Old 09-23-2012, 04:30 PM
D4T_POM's Avatar
Have just read many threads on regarding this and im guessing my Sunroof seal is probably most likely gone as the whole top left headliner is wet and have inspected the left piller which is soaking wet. the drivers side is fine its just the passanger left front side that is wet and as mentioned now my seat does not go back only goes forward.
Goign to get my mechanic to check the drainage on the left side but am sure the drain is not clogged as the sunrrof was closed due to heavy rainfall but for that much water to get in the seal must be bad.
Also guys which part is the seal is it number 7 or 8??
http://realoem.com/bmw/showparts.do?...08&hg=54&fg=05
Old 09-23-2012, 10:36 PM
flow19446 flow19446 is offline
Mein Auto: 745i
im having the same problem but it was my driver seat that stop working,because i left the sun roof lid open and the water got on the seat.after two months the seats started working fine.the sun roof still link but now that i keep the lid close it drips down the side panles ontop the floor
Old 09-24-2012, 05:50 AM
D4T_POM's Avatar
Yep that's exactly whats happening on mine but my car being the UK Spec my Passenger side is the Left side and Drivers is the Right side.
Mine is leaking through the A Pillar and onto my passenger floor.
the reason being my Left (Passenger seat) stopped working is because when id rove off fro stand still last night a huge amount of water fell onto the passenger seat hence I'm guessing the water must of destroyed the Seat Module which is directly underneath the seat.
Anyways I have dropped my car off to my mechanic who said he unblock the Drainage of the sunroof and check all drainage system and also i will get him to change the sunroof/moonroof seal.
Old 09-25-2012, 10:52 AM
D4T_POM's Avatar
Got an update from my mechanic and his checked all drainage system and has found the two left side sunroof drainage to be blocked.
He will strip everything down to double make sure all connections are fine, he also said he will pressure clean it as well as clean it with wires and while doing it with wires making sure no connectors come loose.
Sent from my GT-I9300 using Bimmer App
Old 09-25-2012, 10:56 AM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
Hi D4T_POM,
Did he just remove the A panel or the headliner had to come off as well?
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 09-25-2012, 03:18 PM
D4T_POM's Avatar
Originally Posted by First_745Li View Post
Hi D4T_POM,
As far as i know his removing the headliner.
But will find out tomorrow and get back to you.
Old 09-25-2012, 06:21 PM
Appreciate it..
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 09-26-2012, 06:20 AM
D4T_POM's Avatar
Appreciate it..
Just came back from the garage, he took the A Pillar off as well as the headliner (just the front left side) so he can see the drainage pipes
Old 09-26-2012, 06:27 AM
Ok cool. Thank you for the follow-up
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 09-26-2012, 12:46 PM
D4T_POM's Avatar
No worries.
Im going to go pick up the seal tomorrow.
Going to do the seal as soon as i get it tomorrow (just in case)
Old 09-26-2012, 12:53 PM
No worries.
Just another thing I have to work on ..
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 09-26-2012, 05:00 PM
D4T_POM's Avatar
Lol funniest thing is i never hear a Honda, Lexus or Nissan owner complaining about water leaking in....
We pay all this much for a car like this and the wound keeps getting bigger and bigger lol
Old 09-26-2012, 06:03 PM
That's true. Although I did have a Acura Integra tht had a bad leak in the trunk. I called it my aquarium. But with a flagship car one would expect better. Nevertheless, I love my beast.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 09-26-2012, 06:36 PM
D4T_POM's Avatar
Lol same here....no matter how many times she pisses me off, she is still my beast of a b!tch and i forgive her for the little mess she can make at times
All is forgotten once i take her for a ride lmao
Old 09-26-2012, 07:10 PM
Ain't that the truth! Lol
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
