Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 09-23-2012, 04:47 PM
Michelino Michelino is offline
Mein Auto: 645ci
Unhappy 645ci. 2004
I purchased a 645ci. 2004, the car was running fine now increased immisions showed up then flat tire came on I checked my tire they are fine .Help!
Old 09-25-2012, 12:49 PM
dapirate dapirate is online now
Mein Auto: 645ci
the increased emissions could be a multitude of things, you will need to have the codes read, and every time my flat tire light came on I always had at least 1 tire that was low on pressure. Did you check the amount of tire pressure in each tire or did you just look for a flat?
Also more people may see this, if you post it in the regular 6 series forum, instead of the DIY
Old 09-26-2012, 11:01 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
+1
The colder weather dropped your pressure. Check all tire pressures and get them perfect, then reset TPM. FYI - You have to be driving for it to finish resetting.
For the other, check and reset the codes. But start by getting a full tank of good gas (i.e. Shell or Sunoco 94) and treat your gas with a quality cleaner.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
