Old 09-23-2012, 06:29 PM
jordon jordon is offline
Mein Auto: E39 M5, E60 530i
will e46 rims fit e39?
someone is selling 4 rims and tires from an e46 330xi
will these fit on an e39 540i?
Old 09-23-2012, 06:52 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
No....E46 and E39 are at opposite ends of the spectrum, fitment-wise....
The road goes ever onward....
(R.I.P. Jever)
Old 09-23-2012, 06:56 PM
LalaRay's Avatar
LalaRay LalaRay is offline
Boosted
Mein Auto: 03 ///M5
um........ No.
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower
Supersprint Headers,
Evolve Alpha N Tune,
CNS lightweight dm flywheel/Spec clutch,
ST coilovers,
Eibach Rear Sway bar/Beast Power Brackets,
Drilled slotted Rotors/Akebono Euro pads,
Magnaflow 14816 Mufflers
_____________________________
Old 09-23-2012, 07:25 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
e46 have a different bore size of 72.56
e39 have a 74.1
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 09-23-2012, 08:01 PM
lovemy98 528i lovemy98 528i is offline
My 528i Rocks!
Mein Auto: 1998 528i
If you really want to get them as I found out thanks to fast bob and illestE39 that replied. You can always get a pair of hubcentric adapters to convert 72.56 mm to 74.1 mm center bore. I'm getting a set myself this Friday to put the e60 17 inch rims on my e39. Can't wait,
ilove my 98 528i
Old 09-23-2012, 09:04 PM
NoWayJose's Avatar
i don't think you can do that, its the other way around 74.1 adapters to 72.56
00 BMW 528ia Sport
Old 09-25-2012, 02:35 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
There's also another issue that has nothing to do with the different wheel hub sizes (e39's 74.1mm vs e46's 72.56m)....there's also the wheel offset range difference.
The e39 (like all other 5/6/7/8/Z8 models) has a "medium" (approx 11mm-28mm) wheel offset range...whereas the e46 (like most other 1/3/Z3/Z4/X3/X6 models) has a HIGH wheel offset range (approx 35mm-50+mm). You would need to use wheel spacers to compensate for the different offset range.
PS: with the introduction of X-drive...the wheel offset range for the new 5/6/7 series models that have AWD (X-drive) may also have one or both axles that have a high offset range. If considering any wheels from these new 5/6/7 series models...double-check the wheel's 11 digit BMW part nbr to make sure it is NOT from an AWD model so that you don't get wheels that have the wrong offset.
Q {BMW CCA Member #191509}
(SOLD)
Old 09-25-2012, 02:39 PM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is online now
Mein Auto: 03 Ex Cop 530d Touring
Hi
In short, the faffing around and extra expense you'll need to do to make E46 wheels fit correctly, you might as well buy wheels meant for the E39 anyway. There's LOTS of choices for E39 fitment wheels out there
Cheers, Dennis!
Old 09-25-2012, 03:13 PM
Solo12 Solo12 is online now
Mein Auto: e39 530i e28 535is(Sold)
Dennis and Qsilver make some very good points. But if for some reason you do really want to run e46 rims it may be possible. You need to address two things, the hub bores and the offset of the e46 wheels.
  1. Bore: either elarge the 72.56mm e46 wheel bore to 74.1mm (at a machine shop) or use something like spacer adapters.
  2. Offset: Make sure you can get the wheels and tires into e39 spec with spacers
lovemy 98 528i is correct they absolutley make adapters spacers that allow you to run 72.56mm wheels on 74.1mm hubs. H&R make some in 15mm and 20mm. I know Turner and ECS sell them and I am sure there are other sources as well. I think there was another company that used to make them too ARD maybe?
Here is what the H&R adapters look like
Turner
http://www.turnermotorsport.com/p-86...-5-series.aspx
ECS
http://www.ecstuning.com/BMW-E39-530...eels/Adapters/
Adapters that convert e39 wheels (74.1 mm) to rest of the world bmw spec (72.56mm) also may exist.
Third Option
There is also the option of swapping in e60 wheel bearings/hubs and that will give you the more standard 72.56mm hubs. But in the case of e46 wheels you would still need to run spacers to get them to fit. I don't know much about this and whether it is a good idea or not, but someone did do it and write it up.
http://forums.bimmerforums.com/forum...hlight=e60+hub
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s
E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold]
Old 09-25-2012, 05:57 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For reference:
- BMW wheel specs (1) & BMW & replica wheel styles (1) (2) (3) (4) & the difference between cast vs forged wheels (1) & where to find the wheel markings for proper match mounting (1) & how to choose the right size wheel spacers (1) (2)
