Old 09-24-2012, 07:22 AM
Ahimsa42 Ahimsa42 is offline
Mein Auto: 1997 540i
Hood won't release
I've seen a few threads about replacing the hood release cable, but what about getting the hood open first?
So far, two mechanics (one at the BMW dealership) and a BMW body shop are telling me there is no way to open a closed hood with damaged cables preventing its release.
The body shop is trying to convince me that I will need to cut a hole in the hood to release the latches and then buy/paint a new hood to match.
Can anyone provide me with an alternative approach to getting my hood open, please
Old 09-24-2012, 08:54 AM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
Mein Auto: 1997 BMW 540i
How is the cable worn? Could you pull the trim off the drivers foot well and manually stretch the cable more? I would also yank out the front grills and see what you can get at before drilling holes. I will look at mine later and figure out how I would go about it. Any idea about what is wrong with the cable? Could something also be hooking on the lid holding it down? Did this happen suddenly, or did you buy the car with this problem?
1997 BMW 540i
Old 09-24-2012, 09:46 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I typed /hood F3 and it came up with, I think, your answer, among others:
- How to maintain (1) and repair your hood release bowden cable (1) (2) (3) & how to replace the hood cable the easy way (1) & how to open the hood when the hood cable snaps (1) (2) & how to open the hood manually when you have a dead 12v car battery (1) [or trunk (1) (2)].
Old 09-25-2012, 09:12 AM
I can see the cable attached to the hood release, so it's possible that the cable is merely stretched. The hood is new from a front end collision a year ago, so it's also possible it was attached with too much slack in it or kinked at some point. I've only had the hood opened three times since the accident.
It also sounded as though one Bowden cable would release, leaving the driver side unlatched.
Other than that, I have to assume the cable snapped at some point. There is no easy way, that's for sure. It's hard to believe that gaining entry to what's under the hood is 100% dependent on one small cable that dog legs to serve two latches.
Thank you for the links to other posts. They are helpful.
Old 09-25-2012, 09:21 AM
cn90 cn90 is offline
Search forum, this has been discussed 100x here before.
Old 09-25-2012, 09:33 AM
discovered after post
Thanks, cn90 They have been helpful.
My apologies for the redundancy.
Old 09-26-2012, 07:29 PM
The hood popped with time and patience, but mostly with the guidance of this forum. Thanks to all those willing to help others
bowden, cable, emergency hood release, hood, release
