Old 09-24-2012, 11:09 AM
EmS138 EmS138 is offline
Mein Auto: 335i
What (winter) tyres will fit....
Apologies, hoping someone can provide a specific answer rather than wading through lots of forums posts!
I have a 335i - front tyres are 225/40/18 and rears are 255/35/18.
I'm looking to fit some winter tyres. It turns out that 255/35/18's are a bit rarer than some others, and I was wondering:
1) what would 'fit' without compromising handling etc
2) I'm unlikely to be driving aggressively )winter after all!), but would going all the way down to 225/40, ie the same as the front, still be feasible for the rears (if they would fit?)
Thanks in advance
Old 09-24-2012, 11:13 AM
watchurself watchurself is offline
George
Mein Auto: 2002 bmw 4.4i x5 sprts pg
are your wheels staggered? what does tirerack.com recommend??
if your wheels are staggared than you really shouldnt go same size on the rears -as you'll be stretched
i would get the next size up from the 255/35/18's or what ever tirerack recommends
just my 2 cents
GEORGE
"EVERY FORM OF REFUGE HAS IT'S PRICE"
2002 4.4i BMW X5 - 166K Topaz Blue Ext/ Tan/Beige Leather Int
1994 Nissan Pathfinder SE 132K Black Ext / Grey Leather Int
Old 09-24-2012, 11:15 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
Thanks in advance
225/40/18 will fit fine on the rear.
8.5" rims are a little bit narrow for the 255 they put on there from the factory.
why not go with a 17" rim and tire set? you recoup the cost of the rims after one or two years of mounts and balances.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 09-24-2012, 11:38 AM
Mein Auto: 335i
Thanks for input.
Fair point - what noticeable difference would 17" have over 18"? Probably more comfortable ride! Does come down to cost - plus how long I intend to keep the car for (2 years is probably the max)
Old 09-24-2012, 12:01 PM
Thanks for input.
more comfortable, less prone to damage, cheaper tyres and rims.
Old 09-24-2012, 01:56 PM
8355adam 8355adam is offline
Mein Auto: 2006 330I ZSP
225/40/18 winter tires will fit on both front and back fine. The rear rims are only 0.5 inch wider, this is within the recomended rim width of most tires within the 225/40 category.... also means that the wheels will have almost exactly the same circumference before and after.
Old 09-24-2012, 03:53 PM
Mein Auto: 335i
Thanks everyone, very helpful.
