Old 09-24-2012, 04:37 PM
bharatkv bharatkv is offline
Mein Auto: BMW 2007 X3
My X3 takes long to start in morning
Hi,
I also brought this car 3 months back and had a complete inspection at the dealer and nothing related to this issue was noticed .
2007 BMW x3 less than 52k miles on it.
Recently I am seeing long time to start(cranking for long time) in the morning especially for the first time.
I don't see this issue happen any time during the day after the first start.
Any Ideas?
Old 09-24-2012, 11:31 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Originally Posted by bharatkv View Post
Hi,
Any Ideas?
Battery needs replacement.....typically 4-5 years on the X3.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 09-25-2012, 07:11 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
Hi,
Any Ideas?
Try running a couple of bottles of Techron (one at a time) through it.
Old 09-25-2012, 02:01 PM
Thumbs up
I will try these 2 options and let you know.
Thanks,
Old 09-25-2012, 03:07 PM
swapsafari swapsafari is offline
Mein Auto: 07 BMW X3 3.0si Black
Is this same as any other techron fuel system cleaner that is available in Autozone, etc. or they make it different for BMW's?
Old 09-25-2012, 03:09 PM
Mein Auto: 2004 X3 2.5i
With the ignition key in the 2nd. position (just prior to starter engagement in position 3), you may hear the fuel pump priming.
Some owners here have noticed that it pays to pause a second or so.
Nothing conclusive, but it does seem that for the first start of the day if you turn the ignition key all the way in one quick movement you may experience longer cranking.
Later in the day, it doesn't seem to matter which makes sense.
Also, the Owner's Manual does say to not keep cranking if it doesn't start right away, to avoid cat converter damage.
The second try usually fires straight away. Don't know why - I just accept it.
Old 09-25-2012, 05:59 PM
I think it's the same. I get mine from Walmart.
Old 09-30-2012, 04:03 PM
TheCritic's Avatar
TheCritic TheCritic is offline
Mein Auto: 2007 BMW X3
+1 on this. I treat the gear light as equivalent to a glow-plug light in a diesel--when it goes out it's time to turn the key the rest of the way and start.
2007 X3 3.0i, Monaco Blue with black leather. AT, Sport: 19" staggered replaced with longer lasting 18", Premium, NAV, Heated Seats.
Previous: 2002 Jeep Liberty Limited ; 1999 Mercury 'new' Cougar ; 1987 Mercury Merkur XR4ti
BMWCCA Member since 10/2008
Old 09-30-2012, 05:26 PM
I went to auto zone to find the battery.
I had the rep test the battery.
He did test the battery and alternator and said that some how battery was loosing the charge.
I also got techron fuel bottle as well.
I donot know what is causing battery not to charge fully.
any suggestions?
Old 10-01-2012, 09:42 AM
SonicBoom SonicBoom is offline
Gearhead
Mein Auto: 2007 X3
any suggestions?
If the battery is 3+ years old, it's the nature of the beast.
If not, there is an electrical drain.
Old 10-03-2012, 12:03 PM
any suggestions?
It could be that the battery is just old. It could also be that you're not running the car long enough to keep the battery charged. You may need to get a battery maintainer. Mine sits for days at a time and pretty much lives on "life support".
If the Techron doesn't seem to help the long cranks, try turning the key on and waiting 5 or 10 seconds before you crank the engine. If this helps it could be that the check valve in the pump has a slow leak and is letting the system depressurize overnight. If that's what's going on it's no big deal just continue the pause before you crank thing.
