Old 09-25-2012, 02:22 AM
sheliag10 sheliag10 is offline
Mein Auto: 1998 BMW 538i
High beam stays on
Hello, I have an issue with my high beams staying on. I was told that I needed to replace that LCM. I have a 1998 BMW 528i. I called BMW and was told that I don't have to have it reprogrammed. Can someone help me on how to replace this myself.
Old 09-25-2012, 07:57 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest.com! I've moved your thread over to the E39 5 series forum. Try searching in this forum, I think you'll find what you need.
Tim
Old 09-25-2012, 08:02 AM
cn90 cn90 is offline
Search forum for "BTS426L1".
You can buy this chip on ebay.
Old 09-25-2012, 10:38 AM
kofibmw kofibmw is offline
Mein Auto: E39 520i
yes its true you don't need to go through that, just change this IC BTS426L1. is it both light(Left n RIGHT) that ON or only one?. b'cos there are TWO of the ICs you need to change.
Old 09-25-2012, 08:58 PM
Both of my high beams stays on. Is there somebody that stays in the Raleigh NC area that knows how to put the LCM in for me. I purchased a used LCM and I need someone to put it in for me.
Old 09-25-2012, 09:10 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Take note that if/when you put in the used LCM, you MUST recode it to your car, or else you will get a "Tamper Dot" on your odometer IIRC.
This can be fixed by:
A) Having the dealer do it
or
B) Recoding it with INPA
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 09-26-2012, 12:25 AM
The dealership said it doesn't need reprogramming.
Old 09-26-2012, 04:43 AM
phrozen5100 phrozen5100 is offline
Mein Auto: 2001 540iA sport
If it doesn't need reprogramming, then this is a replacement you can easily do yourself. The LCM is located near the glove box and behind the right most panel on the passenger side.
Once you remove that panel (it's just held in by some clips), you can easily gain access to your LCM.
