E46 (1999 - 2006)
Old 09-25-2012, 08:00 AM
lynie lynie is offline
Mein Auto: 325
Is it the wheel bearings
2005 325 I. First issue was a thumping sound that you would hear when turning to the right. Even changing lanes you would hear it. its loder if you turn a corner but you can also hear it just by moving the sterring wheel enough to change lanes on the highway. Now Im starting to hear a roaring sound. It goes up and down with the speed od the car nothe rpm of the motor. any thoughts appreciated.
Old 09-25-2012, 01:43 PM
Western Skier's Avatar
Western Skier Western Skier is offline
The BIG Voice of Reason
Send a message via AIM to Western Skier
Mein Auto: 1999 323i
I had this sound, and thought it was the bearings too. It was the brake caliber rubbing against the hubs due to the pads being worn down. Get this fixed soon or you will have to replace the VERY expensive calibers.
Proud BMW fanboy
Old 09-25-2012, 02:00 PM
Mein Auto: 325
thanks! can I look to see if thats the problem by taking the tire off?
Old 09-25-2012, 02:15 PM
Yep. I know how to do everything with wheels and all but didn't have the equipment to do so. Ended up costing me 600 dollars at Monro for new rear calibers and pads-which does include pad replacement for the life of the vehicle.
Proud BMW fanboy
Old 09-25-2012, 04:11 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Caliper can't rub against the hub, it can rub against the rotor.
OP, if it is indeed a wheel bearing the noise should go away when you turn side to side.
I don't think $44 is VERY expensive.
http://www.oembimmerparts.com/produc...13-114re46.htm
Old 09-25-2012, 04:15 PM
Mein Auto: 325
It does not go away but there is a slight change to the sound
Old 09-25-2012, 04:16 PM
smolck's Avatar
ROLL TIDE!
It should be a slight change to the better, in other words, the rumbling gets better.
Another option is to remove the wheels and spin them by hand. If they are really bad, you can feel/hear it.
Old 09-25-2012, 04:18 PM
Mein Auto: 325
What about the thump I hear when I chance lanes or turn right any thoughts on that Isblikenthebtire is bad but it's to.
Old 09-25-2012, 04:22 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Engrish 101:
(Examples)
Caliper: on the left
Caliber: on the right
ID:	343282   Click image for larger version
Name:	S&W 625 #5.jpg
The road goes ever onward....
(R.I.P. Jever)
