E36 (1991 - 1999)
Old 09-23-2012, 11:41 PM
Si e30 Si e30 is offline
Mein Auto: E36 M50TU
Lean to the right on RHD
is it Worn RTAB possible to lead into Lean to the right on RHD since noticed that 1" lower on right side compare to left side.
prepare for RTAB DIY ASAP if mentioned part causing the problem
thanks for the Advice B4 anyway
Old 09-24-2012, 04:14 AM
dc_wright's Avatar
bimmerfest Supporting Member
A lot of E36s with stock springs are slighter lower in the right rear than the left. Some with LHD cars have speculated that it's because BMW was trying to offset the driver's weight. This is obviously not the case since your car is RHD. Personally I believe it's due to the weight of the battery and it's far right rear placement.
Some have gone so far as to replace their springs and rework the rear suspension only to find no change when it was all done.
My car sits about 3/4" lower in the right rear and there is nothing wrong with the suspension. When I've had the battery out, the car has been level.
Old 09-24-2012, 01:04 PM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
Yep. Mines a half inch lower on the right. Its weird.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 09-24-2012, 01:36 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I've never subscribed to the "BMW designed the suspension to compensate for the driver's weight" theory for a few reasons. First among those reasons is that BMW does not have individual part numbers for the left & right springs. They're exactly the same. Also, I've never noticed my car leaning.
1998 BMW 328is
1966 Pontiac GTO
Old 09-24-2012, 01:52 PM
Eight Thirty Eight Thirty is offline
Hellawut??
Mein Auto: who knows?
FR:22 1/2
RR: 20 7/16
FL:22 1/8
RL:20 3/4
All measurements were taken in the top middle of the fenders.
more condensed version:
FL 22 1/8....22 1/2 FR
RL 20 3/4...20 7/16 RR
Front L>R difference 3/8"
Rear L>R difference 5/16"
Left F>B difference 2 1/16"
Right F>B difference 1 3/8"
after doing these sounds like my car is totally fcuked up. hahah
-Franklyn
Old 09-24-2012, 01:59 PM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
Back in the game
Mein Auto: 1997 m3
Hmmm...
You certainly make a logical argument Karl. However, experience with my indy mechanic makes things more confusing. He found that my springs were broken last winter when he replaced my rear wheel bearing. He gave, but didn't recommend, the option of having BMW replacement springs ordered. They'd need my vin to match the correct springs to the build options (aka weight +/- 15lbs). Who wants overly engineered BMW springs for $600?
Do we have any BMW damper engineers im haus?
The shot heard 'round the world.
Originally Posted by E36 Phantom View Post
That presenter is getting waaay too worked up over a tarted up VW Golf.
C:\>Sent from my 386 using MS-DOS__
Old 09-24-2012, 02:14 PM
ZeGerman's Avatar
Warm Leatherette
Whoever told your mechanic that BMW matches springs down to +/- 15lbs wasn't correct. All springs for the entire E36 lineup are listed on RealOEM, and they don't have part numbers for springs intended to be used on E36 with more or fewer options. They probably just wanted a VIN so they could confirm the number of cylinders, hardtop vs. convertible, sport vs. non-sport, ///M vs non-M, etc.
1998 BMW 328is
1966 Pontiac GTO
Old 09-24-2012, 04:02 PM
Echo46 Echo46 is offline
Mein Auto: 2006ZCP M3and 1999 M3vert
My car also leans. When I first purchased it I thought one of the springs was broken but nor so.
Old 09-24-2012, 06:53 PM
Back in the game
Mein Auto: 1997 m3
Well I'll bring it up the next time I'm at the shop. He's got a new head tech who worked at a stealership for 15 years. I'll add it to the list of pick-his-brain items.
Old 09-24-2012, 07:37 PM
dc_wright's Avatar
Originally Posted by Eight Thirty View Post
FR:22 1/2
RR: 20 7/16
FL:22 1/8
RL:20 3/4
Nah, just means you need to get out the adjustment spanner for your Racelands while you've got your tape measure out and level it up.
Old 09-25-2012, 11:40 AM
Back in the game
Mein Auto: 1997 m3
A preemptive sorry to the op for taking this a bit off topic, but maybe we'll learn something along the way.
Karl where did you find the spring part numbers?
I checked realoem using my car (11/95) and something close to your car (08/98). Both said to check with your dealer for proper coil springs according to your installed options.
Old 09-25-2012, 01:16 PM
Hellawut??
The rears have no adjusters at all in them... they are just thecutspring.
The fronts i can fix.
-Franklyn
Old 09-25-2012, 01:19 PM
ZeGerman's Avatar
Warm Leatherette
Hmmm... Not sure where I saw part numbers. Maybe I'm incorrect. Even if the springs are matched, I don't think I've ever heard of them being different parts from left to right.
1998 BMW 328is
1966 Pontiac GTO
