High Pitched Noise - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 09-26-2012, 06:07 AM
lal lal is offline
Mein Auto: 2004 e 46 convertible
High Pitched Noise
I've recently developed a noise in my 88 325i, I noticed it after I took the car to a Car-wash where I used the spray wand, co-incidence I believe ?
At about 15-20 mph I'll hear a high pitched whine coming from the left rear wheel hub, goes away when you slow to 20 or so. Friends and I isolated the noise while the car was on a lift with the wheel off, the noise sounds like it is coming in contact with rubber. I took off the axle nut, pushed the axle in a bit, to lube behind the hub thinking that would alleviate the issue, not so. Any thoughts as to what is causing the noise. Auto tranny fyi
Old 09-26-2012, 07:04 PM
downhiller's Avatar
livin large
wheel bearing
Old 09-28-2012, 03:41 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Thumbs down spray wand
I agree with Downhiller
This tool of destruction, you mentioned as a
Code:
spray wand
should be prohibited
So should Oxy Acetalene torches.
You managed to destroy the wheelbearing seal with this
Code:
spray wand
You are not the first !
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 09-29-2012, 12:37 AM
BMWFatherFigure's Avatar
Old School
+1
Current:
E38 Parts Car
Previous:
Old 10-01-2012, 05:12 PM
lal lal is offline
Noise went from consistent to inconsistent to gone, over the course of 5 days, variety of drive lengths, speed so forth, no bearing roughness or growl. ??
Old 10-01-2012, 06:04 PM
downhiller's Avatar
livin large
if its gone dont worry about it. probably rusted something or got some sand where it shouldnt of been and finally worked its way out
Old 10-28-2012, 04:46 PM
lal lal is offline
And the Winner is Downhiller, heard the rumble Thursday, confirmed a failing left rear wheelbearing.
