Old 09-26-2012, 04:34 PM
X3Dave X3Dave is offline
Mein Auto: 2010 X3
New Battery or Battery Tender?
I have a 2010 X3. Recently I've been having problems with the battery. At first it wouldn't start in cold weather. Now it won't start sometimes in warm weather.
I typically drive it two or three times a week totaling about an hour a day (1/2 hour to work 1/2 hour back without stops). I also take it on longer trips once or twice a month averaging 130 miles a day.
During the last warranty service check in May and the technician said the battery and everything else was fine. Looked at the battery and it has a 720 CCA battery.
One day I was listening to the radio for about 15 minutes and then vehicle wouldn't start. Fortunately, I was a my buddy's house and was able to charge the battery.
The most recent incident I don't have an explanation for. The battery went dead for some reason. I jumped it with my other vehicle and then charged the battery.
I don't seem to have problems when I drive the vehicle long distances. It has started fine in cold weather after its been driven a long distance. Is a characteristic of this vehicle if you have to drive it to keep the battery charged?
Last winter I put it on a battery charger as a precautionary measure so it would start in the morning. (It sometimes stays outside). I live in Minnesota so a good battery is mandatory. However, I'm not going to buy a new battery if it isn't necessary.
Old 09-26-2012, 06:50 PM
al_macaroni al_macaroni is online now
Mein Auto: BMW X5
It sounds like you are driving enough and for a long enough duration to keep the battery properly charged. You should not be having battery problems with a two year old car. You may have a problem with your charging system or something electrical is not properly shutting down when the car is turned off and it is draining the battery. The blue tooth module on older model X3s sometimes have this problem.
If you are under warranty, I would take it to the dealership to get it checked out.
2016 X5 35d | Mineral White | Terra
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80
retired - 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog
1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb
BMW CCA #422951
Old 09-27-2012, 06:36 AM
x3brian x3brian is offline
Mein Auto: X3
+1 above. I have an 09 with almost 100k miles and never a start or battery issue. If under warranty I would have the problem investigated at the dealer.
Old 09-27-2012, 09:05 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
It almost sounds like a battery issue. However I agree with al macaroni there might be a charging system issue or a draw on the system.
Old 09-27-2012, 09:44 AM
bowang bowang is offline
Banned
Mein Auto: 2007 X3
Sounds like you need a new battery
I installed a new battery (AutoCraft H8-AGM) from Advance Auto Parts on 09/15/2012. So far everything works great. It's only $125.99 after using a link my friend sent to me. The link saved me $35 instantly. The battery can be used on X3, X5, X6, 3 Series and 5 Series. I got free installation at local Advance Auto Parts store. My local BMW dealer confirmed that there is no need to register a battery on a 07 X3.
Here is the link (up to 40% on everything): http://advanceautoparts.**************************
H8-AGM Spes:
Acid Included: Yes
Battery Type: AGM
Battery Usage: Auto/Truck
BCI Group Size: H8
Cold Cranking Amps: 900
Cranking Amps: 1000
Deep Cycle/Starting: Dual Purpose
Maintenance Free: Yes
Reserve Capacity: 160
Terminal Type: SAE
Weight: 59.45
Length: 13.94
Width: 6.938
Height: 7.5
Warranty:
7 Year Warranty (3 Year FREE Replacement)
Old 10-15-2012, 10:48 PM
Jafega Jafega is offline
Mein Auto: 2007 BMW, X3
H8-AGM Spes:
Acid Included: Yes
Battery Type: AGM
BCI Group Size: H8
Cranking Amps: 1000
Terminal Type: SAE
Weight: 59.45
Length: 13.94
Width: 6.938
Height: 7.5
Warranty:
Thanks for the link bowang! My total came to $113.99 (free shipping) and will be ready for pick up in (2) days for my new battery. This is much easier to digest than the $600 I was quoted...yuck.
