Old 09-26-2012, 05:28 PM
pastman pastman is offline
Mein Auto: 2007 328xi
BMW Antifreeze
Hello Members:
From what I've seen, it seems that I shouldn't consider anything other than "genuine" BMW antifreeze for my 2007 328xi. The best price that I can see is a little less than $30 (shipping included) for this item. I don't mind the price, but it would be much more convenient for me to obtain Peak antifreeze, which claims that it is a suitable alternative to the BMW brand. Please advise. Thanks.
Old 09-26-2012, 05:41 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
It is important to use the OEM anti-freeze in newer model cars.
Short: the antifreeze was made for your engine, which is why it is in there to begin with.
Long: Certain antifreezes (notably 'green') have nitrates and other chemicals in them that BMW did not design the block for. Newer engines rely on different blends of anti-freeze, specifically made for the application. BMW blue is nitrate free, while peak isn't. Those nitrates cause premature wear internally. Another things is hydroelectric conduction. This affects aluminum parts more than anything, because the static electricity that naturally occurs in your engine gets conducted through the off brand antifreeze, and it passes on through the parts, which over time, begin wearing from the inside out. With BMW blue, it nearly eliminates this condition.
Another note, use distilled water. Small coolant passages can clog up with the iron, fluorine and all the other minerals found in tap water. It won't be immediate, but over time those minerals will settle down, and more than likely end up in the heater core or radiator. Once it gets to a certain point, it will clog and will need replacement. Distille water is 87 cents a gallon at Walmart, so there is no excuse to not use it (except dire on the road emergency).
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 09-26-2012, 08:08 PM
Bmw oem antifreeze
Thanks for the reply:
Is this antifreeze "nitrite" or "nitrate" free? Are there no other coolants judged to be free of this material?
Old 09-26-2012, 08:22 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
you need to do careful research...
why not just go pick up a gallon of bmw coolant at a local dealer?
list price is about 20 bucks a gallon. then you dont have to worry about compatiblity.
iirc, the bmw coolant is nitrate, amine, and phosphate free.
different coolants use those as additives. mixing incompatible kinds can cause quite spectacular results.
http://www.fcpeuro.com/products/bmw-...FedxOgodJUoAxQ
if you can pad the order over 25
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 09-26-2012, 09:22 PM
floydarogers's Avatar
Pedant and Curmudgeon
Zerex G-05 is ok: phosphate and silicate-free is the key. If you search, you'll find others that meet the spec G-48.
Old 09-26-2012, 09:37 PM
G-05 is not silicate free... i know at one point it had bmw listed, but the current approvals list no longer has bmw listed. changed formulation? http://www.valvoline.com/products/co.../antifreeze/42
DaimlerChrysler MS 9769 Approved
Ford WSS-M97B51-A1 Approved
MTU/DDC Approved
Detroit Diesel 7SE298
Deere & Company Approved
Mercedes Benz Approved
Cummins 14603 Approved
ASTM D6210
Perkins Diesel
CAT
GM 1825M / GM 1899M
TMC of the ATA RP 329
GE Wind Turbines
Old 09-26-2012, 11:23 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
An assessment of some interest. Couple o'things:
Iron - in a thoroughly inhibited system w/much aluminum, where's iron corrosion product sourced? Municipal water usually treated to remove corrosivity; deliver low iron. Glycols pretty well inhibited against acid reversion.
Fluorides - somewhat soluble, and at very low levels by regulation, prob won't be an issue.
Other minerals - Of these, high hardness in alkaline treated water will form solids in the warmest parts of the system. Big trouble.
Silica - Sometimes in antifreeze to prevent aluminum corrosion, in hard water will form a nasty abrasive grit.
Given that newgen film forming inhibitors perform best in high purity water, distilled or equiv is the only way to fly. What used to be nitrite may be entirely replaced with organics.
Old 09-27-2012, 09:00 AM
RBinDC RBinDC is offline
Mein Auto: 335is Coupe
Low often should the antifreeze be changed?
Hello Members:
My 335is is coming up for its two year maintenance. Will the dealer change the antifreeze? If not should I pay extra to have that done? I plan to keep my car for another 5 years.
Old 09-27-2012, 10:09 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Coolant used to be 4-yr flush interval , now BMWNA says lifetime. "lifetime" is basically the key word when BMWNA doesn't want to pay for it.
for heavy items, like fluids alot of times dealer price is reasonable. I flush my coolant still every 4-yer, out of pocket.
Old 09-27-2012, 10:35 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Well done, Chadley.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 09-27-2012, 12:36 PM
rdorman rdorman is offline
Mein Auto: 2000 imola red 740i Sport
Don't forget that it is not diluted so you need to mix it 50/50 with distilled water. I just bought a gallon for $18.56 plus $1.00 for a gallon of distilled water so $9.78 a gallon which I feel is really good.
bmw antifreeze
