E36 (1991 - 1999)
Old 03-09-2013, 11:24 AM
busy0201 busy0201 is offline
Mein Auto: E36 325I
[M50B25 euro specs] idle problem and power loss
Hi,
I have a idle problem, power lost and for sure fuel consumption grow since 1 year now
These problem's coming sometime not all time.
No problem for start.
No catalysor
Things that are made
- new vanos
- new fuel pompe (2)
- new fuel filter
- new sensor engine temperature
- new sensor aac
- new idle sensor
- new spark performance
- new lambda
- fuel circut tested (pression)
- new ring culasse
- Mass Air Flow Sensor work (i'm sure at 99%)
- air filter ok
- coil tested
Idea's ?
Old 03-09-2013, 01:02 PM
hornhospital's Avatar
D'oh, You Kids!
Two words: VACUUM LEAKS. Find them, fix them. It would have been far cheaper to start there than to throw the piles of money at the car that you have with no resolution to your problems.
Quotes to live by:
Old 03-09-2013, 01:56 PM
Mein Auto: E36 325I
you recommend me to check these parts ??
http://www.realoem.com/bmw/showparts...g=15&lang=enUS
AND
Old 03-09-2013, 03:16 PM
D'oh, You Kids!
Yes, all of that, and EVERY hose no matter how small. All it takes is one tiny vacuum hose with a crack to throw idle and running off badly enough you'll think it's all sorts of other problems, such as fuel pressure.
Like in my signature says: guessing gets expensive. You've been guessing without any evidence of doing any actual testing, and have, as a result, spent hundreds of dollars/euros on it with no substantial change in the running characteristics. A really good investment would be (1) a Bentley manual and (2) a vacuum gauge.
Quotes to live by:
Old 03-09-2013, 03:21 PM
Mein Auto: E36 325I
i think to a smoke test
Old 03-11-2013, 10:32 AM
Mein Auto: E36 325I
what do you think about that ?
Old 03-11-2013, 10:52 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 03-11-2013, 12:33 PM
D'oh, You Kids!
You mean should you do a smoke test to find vacuum leaks? Yes.
Quotes to live by:
Old 03-12-2013, 02:54 AM
Mein Auto: E36 325I
Ok, i do that.
Another thing, these problem's may come from my kn I57 kit ?
Can i drive without air filter for seeing if there is a difference ?
Old 03-12-2013, 05:29 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Une fua!
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
Old 03-12-2013, 06:36 PM
^show off
