E36 (1991 - 1999)
Old 03-09-2013, 10:40 PM
OneBadTexican OneBadTexican is offline
Mein Auto: 1997 328i Convertible
Rough vibration in rear during acceleration and then ok?
I have a 1997 328i Convertible which for some time has been developing a rough vibration in what seems to be the right rear portion of the car at EXACTLY 25 miles per hour. A friend drove with me and he says he feels it more in the center of the car.
Regardless, it's a vibration that feels like something is going to come loose or something but as I speed up the vibration instantly goes away. Like I said, it is at EXACTLY 25 miles an hour and I can't figure it.
I have replaced the tires and rims and aligned front and rear. Had all the bolts on the drive shaft checked. A friend told me he suspected it may be the differential but don't know for sure.
Does anybody have any idea what I might look or what the suspected problem might be?
Old 03-09-2013, 10:54 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Check out the giubo (aka flex disk) - does the car make any noise at that speed like a dull thumping? DS could also be out of balance and 25MPH is where the harmonic frequency creates the vibration.
If you accelerate TO 25 MPH and just maintain the speed, does the vibration continue both under load and while coasting?
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 03-09-2013, 11:07 PM
Yes there is a dull thumping and yes if I remain at the exact same speed that the vibration occurs, the rough vibration will continue until I accelerate past that speed. As I am driving everything is fine but in stop and go traffic it is extremely noticeable.
I have read about the flex disc on other comments and will order one on Monday just to rule that out also. Are there things I should watch out for in order to rule out the differential? Of course I would like it not to be the differential as it would be way cheaper if it weren't but I am not knowledgeable as to what symptoms to look for.
Thanks!
Old 03-09-2013, 11:43 PM
brenna00 brenna00 is offline
Mein Auto: 325i, M3, M3, 745i
Check the flex disc. If that is fine I would suspect the universal joints. You might need to have your drive shaft rebuilt.
Old 03-09-2013, 11:45 PM
I Am The Machine
I don't think that would be related to the diff at all.
Get under the car and look at the flex disk, if it's cracked or deteriorating get a new one, otherwise don't bother. Might pull the DS and take it to a machine shop to check the balance. If the UJs were bad I'd expect the issue to start small and get worse the faster the DS was rotating, but I could be wrong.
// Chad //
You're a derbanana
Old 03-10-2013, 12:13 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
If you do decide to order the flex disc, get a new center support bearing and change it at the same time. You'll have to drop it down to change the disc anyway, and it's not expensive. If the flex disc is deteriorated to the point it's vibrating, it's almost certainly damaged the rubber mounting that the CSB is riding in (it's all vulcanized together).
Pelican has a good write-up on the whole driveshaft removal and replacement.
http://www.pelicanparts.com/bmw/tech.../E36-Guibo.htm
http://www.pelicanparts.com/bmw/tech...ft_Bearing.htm
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 03-10-2013, 12:40 AM
Thank you for your help!
Thank you all for your help and advice. I will leave the differential as a last resort as no one seems to believe that could be my problem.
I will take all your suggestions and try each one at a time.
Thanks again everyone!
Old 03-12-2013, 04:34 PM
Could it be anything else?
I have ordered the flex disc and the center support bearing. I hope this does the trick. In reading several other posts however I am curious as to whether it might be something in addition to those parts. The reason I say this is because to me the vibration seems to happen only on the right rear side of the vehicle. Also, after thinking about it I have prematurely worn the right rear tire twice. To the point where the wire is protruding while the other three tires looked brand new. That's why on both occasions I did a full alignment thinking this could be an alignment problem. I also replace the shocks in the rear but still it wore out this 3rd tire prematurely.
At this time it's the vibration that is really of concern to me because as I am accelerating it vibrates violently on the right rear only but then after 25 miles an hour it's back to normal or at the very least not noticeable.
I am wondering if one of the previous suggestions may be in line with what I am experiencing. That being the possibilty of the u-joints or something right side related.
Any additional ideas?
Old 03-12-2013, 04:36 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
It's Giubo...
Oh wait, you spelled it right! Thanks, Chad!
OP: I hope it works out for you. Seems odd that it would only be at 25mph.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 03-12-2013, 05:01 PM
Is it possible a differential mount could be bad?
Since in my perception the vibration seems to come from the right side, in addition to the suggestions given, is it possible or even feasible to purchase the differential mounts and do everything at the same time or would it be a waste of money until I rule out the flex disc and center mount bearing?
Old 03-12-2013, 05:21 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Have you considered actually getting under the car and inspecting it to see what's wrong? I mean, if you've worn out your RR tire two times, and are working on a third time, something is obviously out of whack. It makes a lot more sense to inspect it rather than just plunking down your debit card and buying parts without confirming what is actually wrong.
1998 BMW 328is
1966 Pontiac GTO
Old 03-12-2013, 05:26 PM
I Am The Machine
Can I ask why you waited 10 posts to mention this little tidbit? That completely changes things. Go look at the suspension on that wheel and see which bushing is completely shot.
// Chad //
You're a derbanana
Old 03-12-2013, 05:28 PM
ZeGerman's Avatar
Warm Leatherette
I'm guessing it's a rear control arm bushing, thereby allowing the tire to go out of alignment, which would explain the vibration at a specific speed and premature tire wear on that corner.
1998 BMW 328is
1966 Pontiac GTO
Old 03-12-2013, 05:41 PM
I apologize
You are all absolutely right! I didn't think of mentioning it until I thought that even though I am the only one that feels it on the right rear and everybody says it feels like the center of the car. But then I thought of the right tire wasting away so rapidly and it caused me to add to my symptoms.
BTW, I have gone underneath and looked for wear on those items suggested and in all honesty they seen fine. I never did however check the bushings which is probably where I should have started. I am still replacing the flex disc and the center support bearing only because I ordered them and they were cheap enough for preventative maintenance. I will check the bushings.
Thanks again!
