E28 (1982 - 1988)
A Quick Enquiry
OK......
I have just noticed the oil pressure light come on in my 87 535i...... I checked the dip stick and the oil is a touch below the 2nd marker........ exactly what is the 2nd marker supposed to be??????? i would check in my brand new BENTLEYS, but have to wait until I receive it from the UK...... Apparently AMAZON.COM will not post to me in AUSTRALIA (scumbags) so I had to purchase from the UK instead (thanks).............. gotta wait 4-6 weeks though!!!!! I'm guessing if oil is correct, then it must be a dodgy oil pressure switch........ another problem to add to the GLITCH LIST Stephen |
The oil level is supposed to be between the two marks, the mark closest to the end being the lower side of the range. Oil pressure switch is a common failure.
Sent from my DROID RAZR using Bimmer App |
My oil pressure switch failed by leaking at the point where the wire connector enters it; very unusual. It's an easy and cheap repair though, they cost less than $20. You may want to actually remove the switch and check the oil pressure at that port with a good quality gauge, it will give you piece of mind.
Don't be gormless; get some gorm! ![/I][/FONT]Last edited by catso; 09-27-2012 at 07:05 PM. |
Thanks to the both answers............. noticed today the light actually went out for about 5 minutes but came back on again................... as for the oil level answer............ glad I am just on full and not dry...... can ignore the light for the next week or so until I hopefully get the BENTLEYS from the UK and a replacement oil pressure switch........
might as well do an OIL and FILTER change at the same time as the switch fix!!!!!! Thanks Stephen |
Source a handbook too!
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
Stephen,
What state are you in?? and I don't mean are you drunk or sober!!
To.... Piston_broke
What state are you in??............. approximately 2000 Ks south of you in VICTORIA.... and I don't mean are you drunk or sober!!..... that's funny and I am straight when I wanna be S#$T FACED...... Stephen |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
