F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
Sport mode
I had a search but couldnt find anything clear.
I have a MY2013 BMW 520d. I am trying to work out what the difference is, if there is any, between putting the car in sport mode using the comfort/sport/eco switcher or by moving the SAT stick over into sports mode? Should i use both? Is one more effective than the other? |
e.g. Sport mode can be configured to change 'Chassis characteristics Only', 'Transmission Characteristics Only' or 'both'. - Chassis Characteristics: Stiffer Suspension/ Tighter steering - Transmission Characteristics: Keeps in Gear longer, shifts at higher revs. Moving the SAT stick to 'Sport Mode' is equal to 'Transmission Characteristics' only I have configured my Sport Mode - only to change Chassis. So, I can get the best of both worlds... 1. Switch in Comfort or Eco Mode, but SAT in Normal : Car is comfy & fuel efficient 2. Switch in Sport Mode, SAT in Normal : Car is stiff/ sharper steering, but still fuel efficient 3. Switch in Sport Mode, SAT in Sport: Car is stiff/ sharper steering, and better acceleration and stays in gear longer (i.e. sport mode) 4. Switch in Sport+, SAT in any mode: car stiffer/ sharper, DSC partially off, better acceleration and gears (i.e. kick-ass sport mode.. real deal) |
What settings do you get in your I-Drive, check them....
There are no settings to change the sport mode that i can see...
Any settings to change Eco-Pro mode?
From what i can see, only to adjust the eco pro settings for a/c etc.
Hmmm. It is possible that Sport config is possible only with VDC. That's why I see it in my settings...
I figure so, can anyone confirm?
I believe I know the answer to this question, however, is the only difference between Sport and Sport + the disabling of DSC? Does the stiffer steering, better acceleration, and holding the gears longer remain the same?
2012 BMW 535xi, Black on Black, Sport Package. 2006 Porsche 911 (997), Guards Red / Black. PREVIOUS BMW'S: 2007 BMW 535i 2000 BMW 528i 1991 BMW 318is |
Yes. The only difference is disabling of DSC (and maybe other safety features as CBC, etc... I do not think it completely disables any of the safety systems... but actually increases the threshold before they activate).
I have a 6-speed manual and DDC, and Sport mode definitely tightens up the suspension about 20% and increases the throttle a blip.
2013 F10 535i M-Sport (Picked up 9/14 from Santa Barbara!) (Sophisto Grau, 6-speed MT, M5 Grille/Trunk Lip, more to come) 2002 E46 330i Sport (Jet Black, 5-speed MT, H&R/Koni Sports, Meyle HD Control Arms, Powerflex FCAB's, Hotchkis sways...and more) 2001 E46 330Ci (Sold) : ( ![]()
I was led to believe that moving the lever to the left makes the car hold the gears longer and disables 8th gear in a non-VDC car only but the Sport button also changes the steering weighting and has sportier engine mapping as well as the features given just by moving the lever to the left.
Might be wrong, wouldn't be the first time... |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
