Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 10-05-2012, 10:41 AM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Not exactly scientific, but an apparent 23 Deg C (73.4 Deg F) drop in Charge Air Temp is awesome.
In general this should be a good thing, but one must also consider the dew point of the air or you can and will get a rain maker into your intake.
You can find this out on dew point tables if you know Temp, RH and pressure.
Sounds very interesting.
Old 10-05-2012, 12:18 PM
62Lincoln's Avatar
62Lincoln 62Lincoln is offline
Mein Auto: 335d
Additional info from Germany:
Wagner kept my old intercooler. They are planning on placing it and the new 335d intercooler on a Flow Bench to test. This should show a lot of results. I also forgot to tell you these temps were at Full Throttle going from 15 mph up to about 120 mph. It was around 220 Kph we got up to very quickly. Also for the panel that requires removal is very easy to remove no cutting involved. Carsten will be making a install manual to go along with the install. The entire install takes 30 to 45 minutes.
Old 10-06-2012, 12:39 PM
cssnms cssnms is offline
Mein Auto: '11 335d
Originally Posted by Axel61 View Post
Here's the latest info on the IC that was sent to DieselDiner:
I just got back after the 11 hours trip with a 45 minute long traffic jamb and 1,160 kilometers to and from traveled.
This intercooler is awesome. Noticed a difference right away. Carsten the owner of Wagner and I did temperature checks before and after the new intercooler install. The old intercooler was reading around 64 degrees Celsius from the intercooler to the intake with an ambient outside air temp of 11 degrees Celsius. The new one had an outside air temp of 12 degrees Celsius and an awesome 41 degrees Celsius from the intercooler to the intake.
The new Wagner intercooler needed absolutely zero cutting of the front bumper to install. Just one piece of plastic had to be removed on the RH side of the intercooler. Carsten said that he would be posting photos. I will post them when I get a chance.
I left there around 1300 my time and around 0700 AM your time. Carsten also stated he was going to put in the word after I left to start production of 100 of them. Again this is a great addition to our already potent 335d engine.
Ok there it is, now BOMBARD Carsten WAGNER!! with questions!!
Excellent prelinary news!
Old 10-07-2012, 08:07 PM
WreckerAFG WreckerAFG is offline
Mein Auto: 2011 335d
For those wondering about voiding the warranty.. I asked a BMW tech, and he said it should only void the warranty to the intercooler and nothing else.
Old 10-08-2012, 04:49 AM
Axel61's Avatar
Axel61 Axel61 is online now
Mein Auto: 335d
Magnusson-Moss Act, you can purchase or install any aftermarket that equals or exceed the performamce of an OEM part
RENNtech Flash, WAGNER IC,Koni FSDs,Execuhitch,VMR710 19"
Old 10-08-2012, 11:03 AM
mflambert mflambert is offline
Mein Auto: '11 335D
The magnuson-moss act can be tough when it relates to aftermarket car parts, especially if the warranty provided will replace the part for free under the written warranty. It (the act) was written to keep OEM companies from requiring customers to pay for their "part" and voiding a warranty if the customer decided they wanted to buy another companies "part" that complied with their OEM's standards.
BMW warranties their OEM intercooler and will replace it free of charge while the car is under its warranty period. If you choose to install another companies intercooler and request warranty repair on "something" that is attached to the intercooler (like everything downstream of the intercooler), BMW has the right to deny warranty repair but they must demonstrate, and document in writing, that the other companies intercooler caused the problem to the part(s) you are trying to get replaced under warranty.
Also, the FTC has validated the right to install "aftermarket" parts, including specialty parts, on a vehicle:
http://www.ftc.gov/bcp/edu/pubs/cons...ts/alt192.shtm
But BMW can still void your warranty, or refuse service/parts free of charge under warranty, if they demonstrate and document that the aftermarket part was the cause of the damaged part(s) you are attempting to get repaired under warranty.
I'm no lawyer and I'm not saying that the Wagner Intercooler doesn't comply with BMW's OEM standards but the magnuson-moss act isn't a 100% safety blanket.
Just trying to help here, these things can get tricky
Old 10-08-2012, 12:16 PM
Axel61's Avatar
Mein Auto: 335d
Vary true i for one would not use the aftetmarket part be used as warranty but i wouuld fight if BMW would try to void the rest of the other parts, i thank u for putting this great information
Old 10-09-2012, 06:30 PM
Mein Auto: '11 335D
BTW the chances that BMW could demonstrate and document that this intercooler we are discussing was the cause of damage to other parts is HIGHLY unlikely. Just sayin'...
Old 10-10-2012, 02:55 AM
Axel61's Avatar
Mein Auto: 335d
Mflambert thats true but knowing the scrubs that they are at times,we the consumers need be adept intelligence wise how to handle this situation whenever it arises
Sent from my SPH-D710 using Bimmer App
Old 10-10-2012, 05:21 AM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Does Wagner have an IC for X5d as well? Do they have a web site?
Old 10-10-2012, 05:54 AM
Axel61's Avatar
Mein Auto: 335d
@finnbmw Carsten told us that they will produce for the 335d's 100 ICs and then move Forward on the X5d eventually. they are doing DATA testing and will provide info in the nearby future, ok.
If you want to know send thm an email, they usually respond promptly.
Old 10-10-2012, 06:22 AM
finnbmw's Avatar
OK, thanks!
Old 10-11-2012, 08:27 AM
Axel61's Avatar
Mein Auto: 335d
ok Amigos just emailed me with the latets info and DATA with price for the IC
Old 10-11-2012, 08:36 AM
Axel61's Avatar
Mein Auto: 335d
I sent 62Lincoln an email with the files so that he can load them up in the site ok amigos!!
Old 10-11-2012, 11:18 AM
62Lincoln's Avatar
Mein Auto: 335d
Some new pictures, showing the factory unit alongside the Wagner unit. The last picture was taken from below Matt's car showing the unit mounted:
Old 10-11-2012, 11:23 AM
62Lincoln's Avatar
Mein Auto: 335d
This image is a graphic representation of the temperature deltas that were reported by Matt on the day of installation. Not new information, but the info presented in a graphic format:
Old 10-11-2012, 11:27 AM
Axel61's Avatar
Mein Auto: 335d
Amigo the photos did not come thru!!!
Old 10-11-2012, 11:46 AM
Mein Auto: '11 335D
About a 45f drop. Very impressive!
Old 10-11-2012, 11:53 AM
Axel61's Avatar
Mein Auto: 335d
here's the email he sent me:
mit freundlichen Grüßen / best Regards
Carsten Wagner
Von: Wagner-Tuning [mailto:info@wagner-tuning.de]
Gesendet: Sonntag, 7. Oktober 2012 15:55
An: 'Axel Hernandez'
Betreff: AW: AW: 335d Intercooler
Hello axel,
every went fine on Friday. Intercooler fits like a glove. We had a temperature drop of aprox. 23°.
We are going into Production now.
Thanks.
Here is the facebook message today:
Wagner Tuning USA
what about renntech?
yes, you can post it...
people want believe it mostlym because we did it by ourself
but Matt, was here abd he has seen it in person :-)
Old 10-11-2012, 06:45 PM
GreekboyD GreekboyD is online now
Mein Auto: 2009 BMW 335d
So I was on the Wagner Tuning website adding the IC to my cart and something caught my eye and gave me an idea:
Why not try for a group buy?
Old 10-11-2012, 10:30 PM
Mein Auto: '11 335D
Interested
Old 10-12-2012, 05:01 AM
Axel61's Avatar
Mein Auto: 335d
as far as I am concerned either MArk or Nick from WAGNER mentioned to me as well as 62Lincoln a group buy, IM IN!!!!
Old 10-12-2012, 12:56 PM
Axel61's Avatar
Mein Auto: 335d
This is the message I got from NICK
Wagner Tuning USA Jonathan Ruan we will have them here in the US in 45 days!! email me your contact info and I can keep you updated on it. Here my email nick@wagner-tuning.com
Old 10-12-2012, 02:10 PM
Mein Auto: '11 335D
Excellent news! Thank for you staying on top of this and providing the great communication!
Old 10-22-2012, 08:13 PM
Mein Auto: '11 335D
Group buy!
HTML code is Off
