Old 09-27-2012, 11:42 AM
natgreen natgreen is offline
Mein Auto: 1996 BMW 528i
1996 E39 528 Left Front Noise after brake job
Completed changing the Front Brakes, Rotors, and Pad on my 1996 E39 528I BMW. My fist time attemting to do such. Upon completion of the job, I noticed a noise (grinding) coming from the front left driver side. Took off the wheel, re-check my work, drove the car again....same noise. I am trying to figure what I did wrong.
Old 09-27-2012, 04:19 PM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
a broke down melody
Mein Auto: It has two dipsticks
Welcome to bimmerfest
Old 09-27-2012, 04:38 PM
anton831 anton831 is offline
Mein Auto: 528i
is your abs sensor installed right
Old 09-27-2012, 06:21 PM
black528i black528i is offline
Mein Auto: 97 528i
Have you tried this ... http://zeckhausen. com/bedding_in_brakes.htm?
Old 09-28-2012, 03:43 PM
Mikes530 Mikes530 is offline
Mein Auto: 530
Sounds as if something (maybe the splash shield) might been bent or mis-aligned and is contacting the rotor. Your best approach would be to get the wheel off again and manually spin the rotor to catch the noise. If no noise repeat the process with the wheel on and properly torqued. Make sure you support the car properly on stands.
Good luck
