7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#26
'11 328i '03 745Li '03 Acura TL-S '02 Infiniti QX4 |
#27
Thanks. I'll look for the legal disclaimer in the MMI tomorrow.
#28
I found the MMIGT module, anything close to MMI module. When I try to read the ECU (expertmode) I get the following error.
#29
Going to try this asap.
#30
Stuart |
#31
Windows 7 Prof
#32
Are you referring to this error in the C:\NCSEXPER\BIN directory?
#33
How did you determine what parameters to use for each keyword? NCSDummy doesn't show any E65 settings...
2005 745i Individual |
#34
If your car was produced before march 2003 then a minor wire change is needed, it's just swapping a pin in the connector to the light module. Keyword parameters? Are you referring to the coding values? That's correct the LM2 does not have any coding values for chassis type, when I first fitted it the lights didn't work properly because it still thought it was in an E60! I re-flashed the LM2 using winKFP (I'm not sure this was actually necessary, at the time I thought there must be chassis specific software installed as there were no coding parameters) this was successful and allowed me to ensure the VIN number had taken. You then need to copy the vehicle order from the CAS and write it to the new light module, then code the light module using the expert profile, this automatically configures the light module based on your vehicle order, like if you have xenons etc.... Do not use the cowboy method of deleting the contents of a .MAN file and writing it using a coding manipulation profile, your asking for trouble. There is a correct method for doing automatic self-coding, there are loads of PWM values for the LED brightness that are coded automatically too. You then read the trace file and edit it a you wish once you have it all working and activate the welcome lights, home lights etc.... And remove the bulb checks so you can install LED indicators etc.... Very worth while upgrade in my opinion! Stuart |
#35
Thanks for the info and mini-guide for coding changes! Somehow I overlooked the LM2 modules listed for E65. I will be doing this upgrade. For others reading this thread, see attachment for valid coding indexes.
#36
Interestingly NCS expects to see an LMA when you go to read/code it, but then automatically changes to the LM2, it does not do this for the MMI, if you fit a facelift one for example. So you don't have to dummy change your production year in NCS to code it. Stuart |
#37
You know you guys can also code VIM (video in motion) in which you can play dvd movies in the front navi screen! I just coded a couple of 7s for this..A 2007 and a 2008.
#38
I an '03, do you think it's possible or is this for facelift models only?
#39
Hmm. What module is your MMI? Do you have a rear entertainment center? I asked this question on the other forums And I did not get Any answers of what model year this can work from. I know 2007 and 2008 works. I can try this for your car if you want. I can send the modules scripts that I edited in the SPdaten for the E65. You want to try?
#40
#41
#42
That's its. I know it's the mmigt module but in the daten files it is listed as MMI!!
Text me 917-939-4980 Last edited by cn555ic; 10-21-2012 at 09:14 PM. |
#43
well see if this works tomorrow by 800pm...Keep you guys posted of our endeavors! lol
#44
Q: are you charging for coding services on this site?
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
#45
No I am helping Fez try to get VIM working for his car! I just sent him the files!
#46
I thought so, just asking
... Always glad to have another coding expert on the site.
#47
Do you do any remote coding
#48
Yes I can but you have to have the cable and the programs working on your laptop...If you dont have the programs, I do offer services to configure the laptop for people which takes about an hour or so, but I dont like doing because its a PITA to configure it. Last edited by cn555ic; 10-21-2012 at 09:27 PM. |
#49
What programs?
#50
INPA, NCSexpert is all that you would need...Plus the Dcan cable and a laptop running Windows 7 preferably 32bits...
We are going to try Video in Motion on First 745 LI tomorrow....I got it to work on a 2007 and 2008...I just read it works for 2003-2008 so we will see tomorrow....Video in motion for this application does not require any added modules or adapters to make it work...Its simple coding and edited Spdaten files which a Coding block had to be added to MMI module scripts to make it functional.. Last edited by cn555ic; 10-21-2012 at 09:35 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
