7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#76
Surely you have TV option in the USA? Your saying even with the TV option you can't code video in motion?
Trying to code video in motion with no actual video source..... That would be rather pointless. |
#77
He didn't say he put a DVD in the NAV drive, (unless I missed it!) he just said he has coded video in motion, which means he must have a video/TV module. Which is the same as me, I have a digital video module which is now enabled to work while I'm driving. I don't have a DVD changer. (But I do have a DVD NAV! Lol) Stuart |
#78
If it was my coding that was the problem, I wouldn't have been Able to code 2 cars that had RES and allow video to show in the front Navi screen, so that confirms my files are correct Last edited by cn555ic; 10-23-2012 at 12:57 PM. |
#79
I think you have just misunderstood what he was saying, there is no way on earth that the NAV drive will play a DVD video disc, that's not what it's intended for.
I bet he has just the video module like myself. This is mine, fitted it yesterday! ![]() Have you been trying to code a car with no DVD or video module to play DVDs from the NAV drive? All this coding does is removes the warning message on the MMI when you engage drive or reverse. Basically saves you the hassle of installing that cheap Chinese crap to the MMI CAN bus interface to alter the CAN messages. And is free of course! Stuart Last edited by stuartjohn24; 10-23-2012 at 01:04 PM. |
#80
He said he has DVD navigation, but never said he put a disc in and played it. I think that was just extraneous information.
And, no, there is no TV option in the USA. The digital broadcast signal is different and no module is available to support it in a car. |
#81
Sucks that US based cars doesn't come with this feature. |
#83
Hence why I got the hybrid module, they are scarce and expensive! How does the DVD video interface connect to the MMI? I'm sure it has to route through the video module? With no rear entertainment it's a CVBS signal to the video module, then switched to the NAV, with rear entertainment it's CVBS to the video module then RGB to the MMI, also NAV now outputs CVBS signal to video module instead of RGB to MMI. Anyway, glad we got that cleared up! |
#84
You can code TV_VIDEO_ABSCHALTUNG from aktiv to nicht_aktiv to enable video on the front screen while parked. I'd test that before bothering to disassemble and edit the module code for video-in-motion.
#85
Already tried that. US based models do not work
#86
No he does not, hence this is what this discussion was all about...I was able to code in Video in Motion with cars that have RES...I was mistakenly told that it would work without RES so I tried to code a car yesterday without RES.. It doesnt work and was told it can but now we realize the person that told me had Euro specs and not US specs which does not have video module.
#88
Based on my research, 2002 - 2005 North American spec E65/E66 with RES were built with an analog TV tuner built into the video module. Hence the owners manuals list TV as a source for the rear seat passengers. For 2006 - 2008 the TV tuner was removed and RES cars were built with a video switch.
I do not have RES, but I retrofitted a Euro analog TV tuner / video module and can watch video in motion... though it's mostly static as analog signals are rare in NA. Later I added the DVD changer and now video in motion has more purpose.
2005 745i Individual |
#90
Help me Exx coding
cn555ic hello my name is angel on the advice of shawnsheridan I decided to contact you for help how to install upward upward pc (Exx) coding I've also downloaded the latest version of sp daten. can you give me directions ... thanks
#91
Where did you grab the latest daten files? I'd like to code some stuff on my E90 LCI but all of my files are dated 2010 (my car is a 2011).
#92
I'm interested on your service to configure my laptop I'm in NYC area thank you and let me know if your around NYC!
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
