Old 09-27-2012, 08:04 PM
nucleotide nucleotide is offline
Mein Auto: F10
Map Update Activation Code
Wondering if anyone has seen anything in any modules where one can remove the requirement for entering an activation code for the latest maps.
Have obtained the latest maps (~30Gigs of data) and the thing is asking for an "Activation Code".
Thanks in advance...
Old 09-29-2012, 10:31 PM
gotrice415 gotrice415 is offline
Mein Auto: M3, 335Ci, X5d, 750i
Not possible. This is required to activate. Similar to Windows or Apple software, you need to pay for activation code.
Old 10-03-2012, 02:26 PM
legaleye3000 legaleye3000 is offline
Mein Auto: F30 328i Sedan
How do I know what the latest maps version is so I can compare to my car's version (2012 F30, build date of Dec 2011)? Thanks.
Old 10-03-2012, 03:35 PM
332701 332701 is offline
Mein Auto: 535xd
start your navi, then press Option and you should see something like this:
535xd with 20'' Wheel style 434 M in Sophistogrey II Brillant Metallic
Old 10-03-2012, 03:37 PM
I know that... But I don't know what the latest version is so I can compare to the version my car is showing me... Thanks.
Old 10-04-2012, 05:52 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Right now, 2012 North American Premium is the latest available for CIC. The 2013 version is due out any day now though, so I would not update until 2013 is released. Then, you can buy the FSC Code for it for $50. Do not go to the Dealer, or it $300 - $400.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 10-04-2012, 06:08 AM
Oh ok. Thanks for the info. Do they give you a change log? Also, where can I download it when it comes out and where do I purchase the code from?
Old 10-04-2012, 06:42 AM
I have never seen a change log.
The maps are huge. For regular HU_CIC, it's 3 each 8 Gb DVD's (24 Gb), and for the new HU_NBT, it is 6 each DVD (48Gb).
In the past, you could order them from your dealer for only $10, because basically all you were paying for is the medium itself (DVD platter cost's) and not the actual Content, as the Content cost is in the FSC Code. BMW got wind of what was going on and killed the DVD Sales, so I am not sure what to expect this year.
That said, I have a source, and I believe I will have the HU_CIC DVD images very soon, and I will make them available.
For FSC Code, you want to contact sieras5 (Sergej):
sieras5 @ inbox.lt
Old 10-04-2012, 12:43 PM
Ausfahrt Ausfahrt is offline
Groccery Getter
Mein Auto: E46 325iT/F10 550
sieras5 @ inbox.lt
Looking forward to this Shawn!
Old 10-04-2012, 08:45 PM
yushow5069 yushow5069 is online now
Mein Auto: BMW E39
If you can read 001bfsc.... file i can decode it and generate fsc code for you.
Old 10-04-2012, 10:40 PM
Dr.Frankenstein Dr.Frankenstein is offline
Mein Auto: F11 530D
Any tips on how to retrieve this with E-Sys and/or what software is required to retrieve this file?
Old 10-05-2012, 12:44 AM
Mein Auto: BMW E39
this too should work under inpa ec-apps also on c:\ediabas
Old 10-05-2012, 04:51 AM
vierchatura vierchatura is offline
Mein Auto: Renault 19
Here it is SWID Reader for reading 001B FSC file. Rename file from .pdf to zip
Old 10-05-2012, 06:43 AM
chris88 chris88 is offline
Mein Auto: bmw x3 F25
i have only the esys. is this also possible to make this file?
did you generate the fsc for 2013 maps?
Old 10-05-2012, 06:46 AM
He just gave you the program to read your 001B FSC file, SWID Reader. To use it, Copy it to your existing C:\EDIABAS\Bin folder and run it.
Old 10-05-2012, 07:02 AM
i have do this, but i receive following error, if i press connect. (f-model)
Old 10-05-2012, 07:13 AM
Win 7 64-Bit?
Old 10-05-2012, 07:54 AM
yes
Old 10-05-2012, 08:01 AM
yes
That is why. It will only run on 32-Bit OS. You can try running it virtualized in XP Mode.
Old 10-05-2012, 09:05 AM
this have i try now, but the problem now, is the network connection in virtual win xp. the network adapter take not the ip adresse from the car.
is there any special settings? Thanks for you help.
Old 10-05-2012, 09:09 AM
Sorry, I don't know, as I have not tried it. I know though people are running E-Sys on Mac OS with XP virtualized, so it must be possible with a virtual LAN port.
Old 10-05-2012, 09:59 AM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
The car does not have a DHCP server; so it does not assign an IP to the computer. Both the computer and the car will go into DHCP fallback mode, each assigning themselves a random class-B address so that they can talk to each other. This can take up to 60 seconds, so you have to wait until the computer has an IP address before you try to connect.
Also, make sure you set the VM NIC to bridging mode, not NAT.
Old 10-05-2012, 09:21 PM
Mein Auto: BMW E39
Yes i can generate 2013 fsc code. but you need SWIDreader under C:\EDIABAS to read out 001Bfsc file and i will generate fsc code for you.
Old 10-06-2012, 04:38 AM
now, it works. i take an old pc. i have send the file to you pm
Old 10-07-2012, 12:56 PM
FrogmanF30's Avatar
Are the 2013 Nav disks even available yet?
activation code, maps
