1988 635 no fuel delivery - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 10-06-2012, 11:40 AM
algee608 algee608 is offline
Mein Auto: 635.850,525,530
I own a 1988 635csi. I started it yesterday and let it run for five minutes then it suddenly died. It would not start but when I shot ether it ran for two seconds then died again. I do not want to throw parts at it so where should I start.Bad fuse? bad relay? Please advise
Old 10-06-2012, 10:15 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Fuse 11 controls the fuel pump (among other things). Check it. It is the eleventh fuse toward the fender counting from the inboard side of the right-hand fuse row. It's supposed to be a 15 amp fuse.
Check for voltage at the pump itself. If the fuse is good but you have no power to the pump, check the fuel pump relay for function. It should be the relay on the front side (toward the front of the car) of the fuse panel.
If you have voltage to the pump, pressure test the pump anywhere down-stream of the fuel pump itself. Easiest is up on the fuel rail inlet.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 10-07-2012, 03:18 PM
Smile 635 no fuel delivery
Thanks so much for the info:
HTML code is Off
