Old 09-28-2012, 02:27 AM
markwarren markwarren is offline
Mein Auto: 745i
reduce acceleration, hard acceleration may damage catalyser
hi all, just had the message
reduce acceleration, hard acceleration may damage catalyser. Any ideas what the problem is. The car is a 2002 745i with 80k on it.
i did have a mis-fire a few weeks ago but stopped the engine and turned it back on again and it was fine?
any ideas?
Old 09-28-2012, 06:09 AM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Have you checked to make sure all the coils are plugged in? have you recently change the spark plugs? do you have access to a OBD code reader?
If the first two arent true, if you can get to an OBD get the codes read out, find out what cylinder the misfire is, take the coil out and swap it with another cylinder's coil, if the code moves to the cylinder the coil was moved to then the coil is bad, if not check the spark plug in that cylinder and wire connections to the cylinder. matter of fact no matter what always make sure the coil is seated properly and that the plug into the coil is seated properly just incase you move the coil and then the code moves.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 09-28-2012, 06:17 AM
Mein Auto: 745i
thanks for that mate, I had a similar issue some years ago with an audi s8 but as the 745 is a lot more technical i wanted to check. Dont have any electronics to test but I will get a mechanic to check the plugs next week. I did have the rocker cover gaskets changed a few weeks ago so that might have disturbed something!
Old 09-28-2012, 11:04 AM
chrisrees chrisrees is offline
Mein Auto: 02 745li
Coils
Repairs 2012
wishbone & steering rack
Rfmd hydro steering gea
combination nu
Ball Joint
Tension strut with hydr
Switch unit steering column
Coils 5&7 and new spark plugs
Faulty DSC Control Module
Fuel Gauge
Leaking Crank Case Vent Valves
Power Steering pump, washer pump and grommont,
Crank Shaft position sensor
Total $13,481.37 in one year my mechanic swears all these parts are re engineered to work better than the originals lol
Old 09-28-2012, 11:07 AM
Mein Auto: 02 745li
any ideas?
And now the real repairs begin at 80,000 miles.
Repairs 2012
combination nu
Ball Joint
Fuel Gauge
reduce acceleration
