All BMWs pls help JBE coding without wiping supercharger software on ECU:e92 M3 - Bimmerfest - BMW Forums
Old 05-17-2017, 08:04 AM
Got M Got M is offline
Mein Auto: BMW
Hey guys, have a 2011 Supercharged e92 M3 and in a little bit of a pickle here.
Had the car stored for the winter, went to pull it out and now the JBE needs to be replaced as per the dealer.
They can do it for a hefty price but it would wipe the supercharger software and would need to be sent to the supercharger manufacture to get the ECU reprogrammed.
My question is: is there any way to pair a JBE with the car and not have to change programming on the ECU?
Any help would be greatly appreciated.
Old 05-17-2017, 09:37 AM
oceandiver86's Avatar
oceandiver86 oceandiver86 is online now
Mein Auto: z4
with WINKFP and NCSexpert you can program and code a single ECU.
The Dealer on the other hand works with ISTA-P and re-writes (update) the Software on every ECU which has a newer Firmware available.
you can get the BMW standart tools from this forum.
also its possible to fit and code a used JBE, just the hardware needs to match.
you don't need to touch the DME module.
