Closed Thread
Old 11-16-2012, 03:09 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by vzinic View Post
1. Yes my token file is Code Away.est.
2.My E-Sys / PSdZData 46.3's work before and I successfully coded.
3.No I do not merge two sets of PSdZData, only 47.5
4.After that I remove 47.5 and again go on 46.3 and it is not work.
My car is Prod.date 2011-11-07 and I do not no version of ISTA/P in my car.
It is not programmed by the dealer.
Today I will try to re-install all Esys,and I'll tell you if were successful.
Best Regards,
Ok. Thanks for confirming, and let me know how the reinstall turns out.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
  #202
Old 11-16-2012, 06:40 AM
wassy's Avatar
wassy wassy is offline
BMW Enthusiast!
Mein Auto: '08 750i
Originally Posted by shawnsheridan View Post
When did you take delivery of it from your Dealer?
Where did you get your ENET Cable?
I bought it 2 weeks ago. Was the GSM's demo. I was told by my service contact it had software done in August. I bought the cable from April1. Very solid looking cable.
'13 640i Gran Coupe Alpine White/Cinnamon Brown, M-Sport, Driver Assistance, Lux Seating, Premium Sound, Full LED's
'10 Porsche Panamera S
'09 Maserati Quattroporte S
'08 550i Carbon Black/Natural Brown/Anthracite, Sport Pkg, Active Steering, Comfort access, Sport transmission, rear shades, NAV, Sirius, L7, Ipod/USB, PDC, Heated Front Seats.
'08 750i Sapphire Black/Natural Brown
'06 750i Sapphire Black/Natural Brown
'07 550i Sapphire Black/Black
'05 545i Silver Grey/Black
  #203
Old 11-16-2012, 06:59 AM
Ok. I do not think the issue is old PSdZdata or the cable, so it is something else. What it is, I am not sure though.
  #204
Old 11-16-2012, 07:28 AM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
Well I'm glad we were able to solve the problem. Lol. If you have any ideas let me know. I'm out next week and was hoping to mess around before I left.
  #205
Old 11-16-2012, 07:36 AM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
I will say that when I open esys and look at help/about it shows esys 3.18.4, BUT PSDZ version 4.4.0.0. Definitely not 47.5. I can't get this to change.
  #206
Old 11-16-2012, 10:45 AM
hkn0626 hkn0626 is offline
Mein Auto: 2013 328i M Sport
Can someone please seed?
Thanks!!
  #207
Old 11-16-2012, 01:01 PM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
Shawn,
Just dropped car off at dealer for some minor service. Will be there all week. Per key data:
Integration plant. F010-12-03-512
I-level HO. F010-12-07-531
  #208
Old 11-16-2012, 01:52 PM
vzinic vzinic is offline
Mein Auto: F10 520d
I solved the problem!!!!!!!!!!!!!!!!!!!!!!
In version psdz data46.3 when you go on open connection:
TargetSelector:Project=F010 11 09 504,VecihleInfo=F010 DIRECT
Everything worked ok.
But now with psdz 47.5 you must go to:
NO " DIRECT" ,and now works.
  #209
Old 11-16-2012, 03:04 PM
Shawn,
With an I-Level of F010-12-07-531, you have one the four ISTA/P versions on your car:
ISTA/P 2.47.0
ISTA/P 2.47.1
ISTA/P 2.47.2
ISTA/P 2.47.3
It's not always and exact science as you can see. In any event, the 47.5 PSdZData is current enough for your car.
  #210
Old 11-16-2012, 03:11 PM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
Super! Problem is it doesn't work. Lol. I have seen some batch installers that place esys and data in their correct place and presto, it works. I doubt that is my issue as I am connected. I tried the batch installer from April1 (posted here somewhere) but keeps saying directly or folder missing. I named it exactly as it is in the .bat file. Don't get it.
I could try the opposite as Vzinic and attempt direct connect at the fa screen???
I did ask dealer for updated software but will see. Have a slight tranny banging issue and somewhat rough idle. Maybe they will update it all.
  #211
Old 11-16-2012, 03:15 PM
I did not think to ask you that, but yes, you can not use the _DIRECT Target. I am actually surprised to hear you were able to do so with 46.3.
Thanks for figuring it out and letting people know the casue and correction.
  #212
Old 11-16-2012, 03:19 PM
Wait. You named what exactly as it is in the .bat file? Which one of April1's batch files did you use with your 47.5 PSdZdata, and what exactly was modified by you?
Do this:
1) Delete you entire PSdZdata folder (including all subfolders) from C:\ESysData\.
2) Without running the batch installer, manually copy the extracted PSdZData folder to C:\ESysData\ so you end up with C:\ESysData\psdzdata.
3) Try and connect.
  #213
Old 11-16-2012, 03:42 PM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
Wait. You named what exactly as it is in the .bat file? Which one of April1's batch files did you use with your 47.5 PSdZdata, and how what exactly was modified by you?
Let me clarify. First there are quite a few slightly different install instructions around. I followed yours twice after clean install. Followed his once. I then found a file he recently updated called something like "auto_setup_esys3.18.4_PZDData_47.5.exe.bat" or something like that. Hen I ran it told me folder or directory now found "c:\bmw_esys3.18.4\esys3.18.4" and a couple other similar directories.
I did not modify his bat at all not anything else. I simply placed esys folder and PZDData folder in a folder named what the bat file was looking for that generated the errors. In other words I tried multiple different was to properly install and it may be installed fine. But I rerouted back to square one after 2 days of fiddling and torment.
  #214
Old 11-16-2012, 03:44 PM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
Do this:
3) Try and connect.
Ahead of you. Did that 3 times. Also double checked est location pointing and ediasys.ini file for enet connected as well as Dist folders in each build. All there!
  #215
Old 11-16-2012, 03:46 PM
Ok. I am out of ideas. Sorry.
  #216
Old 11-20-2012, 08:36 AM
dercur dercur is offline
Mein Auto: 745li
can someone share with me where to get psdzdata files thanks
  #217
Old 11-20-2012, 08:39 AM
http://www.bimmerfest.com/forums/sho...&postcount=176
  #218
Old 11-21-2012, 01:22 PM
Utzeman Utzeman is offline
Mein Auto: 320d
@ shawn
Hi shawn.
Are there any news about the E-Sys v.47.5 psdzdata links?
regards utzeman
  #219
Old 11-21-2012, 01:24 PM
Originally Posted by Utzeman View Post
@ shawn
Hi shawn.
regards utzeman
See this Post:
  #220
Old 11-29-2012, 08:06 PM
hiroyuki hiroyuki is offline
Mein Auto: BMW X3 F25
Hi Shawn,
Can you please PM me the links for 47.5
Thanks,
  #221
Old 11-29-2012, 09:31 PM
Originally Posted by hiroyuki View Post
Hi Shawn,
Thanks,
Full 47.5 PSdZdata or the 45 new CAFD's from 48.1?
  #222
Old 11-30-2012, 02:29 AM
What is the 45 new CAFD's from 48.1?
Teach me,please.
the 45 new CAFD's from 48.1 is PSdZdata file?
  #223
Old 11-30-2012, 07:33 AM
April1 April1 is offline
Mein Auto: X3 2011
psdzdata 48.1 has additionally 45 new cafd files over psdzdata 47.5
  #224
Old 11-30-2012, 08:02 AM
Teach me,please.
Add them to your existing 47.5 PSdZdata in C:\ESysData\psdzdata\swe\cafd folder.
This works for the vast majority of people, although there may be a couple CAFD's that still require the full PSdZData package such as F10 KOMBI cafd_00000069-009_000_050, and possibly F30 FEM_BODY cafd_00000794-004_124_042.
  #225
Old 11-30-2012, 01:00 PM
Dear Shawn
Verry Thanks!
I understand well.
Please sent me the links for new full PSdZdata file.
My BMW is F25!
Closed Thread
