E34 (1989 - 1995)
changed waterpump/engine wont start
Okkay. I have a 1994 bmw 530i and about 2 months ago the waterpump went out, so the car just sat there tell about yesterday, when I got a new waterpump, I replaced it with a brand new one, and it would not start, it sounds like it wants to start but Doesn't turn over, the starter and fuel pump are working. I. Was told that I might have to reset the engine. But idk.. anybody have any ideal. O and when the waterpump went out it still started....
And are you sure about the Fuel pump? when you turn the key to accessories, you should hear a light humming coming from the right side of your trunk. if not, check the FP relay as that is where my No-start issue was... Good luck EDIT: also i see this is your first post. Welcome to the B'fest E34 crew! the happiest forum on the planet
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros Last edited by Monsignor; 06-01-2012 at 06:52 AM. |
Depleted battery or no gas.
I have gas and the I had the battery hooked up to the battery charger.. umm and how do I check the resistant on the crankshaft sensor? And thanx 95 e34
with a multimeter. download a bentley manual for the car. it will tell you how to check the CPS. Although, the voltage in the bentley is a typo, it should be 540 OHM not the 1140+ in the manual...
Find the CPS, its on the front of the car, under the radiator hose on the passenger side pointing down at the harmonic balancer. The wire to it runs from under the intake manifold, along the front near the VANOS and down to the sensor. Unplug at the connection under the intake manifold and thats where you'll check it.
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
Allright thanks..
I think that enough /dirt grease can lodge under the cps to disrupt the pulse of the sensor. Also check that the wire is not damaged. Another idea is possiable that car is flooded.
The car was flooded after a few trys, I took the plugs out and cleaned them off. Then let it sat for a couple hrs. And then tryed.. but im jus goin to see. If theres somethng under the cps
Try starting the car without MAF, and do fuel DELIVERY and pressure holding test.
Oh excellent nothing serious .You may be in line for a fuel filter soon.
Does the crank shaft need to lined up correctly with the crank shaft sensor? If so I believe thats my problem, and what would I need to do?
How is the resistance? ![]() From the bentley, but the information is WRONG. M50/M60 engines should also have a 540 +- 10% ohm reading. |
I changed my crankshaft sensor and still wont start.. iz there any way to figure out why it wont start?
Gotta run through these:
THE DEFINITIVE "NO START" trouble-shoot instructions - Bimmerforums - The Ultimate BMW Forum |
thats bold haha
It's not getting ignition if it floods with fuel so the timing could be off. The CPS controls timing but you say you changed it so pull a plug and see if there is spark.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot. |
If you are getting a spark and fuel either the CPS is in the wrong place (same casting used on various models so two mounting points), or plug leads are on wrong plugs or wires on wromg injectors. We've all made these mistakes....once.....
Why have none of you laid off rocket scientists told him to check the fking error codes? Do a stomp test first. Stop flinging feces at a wall like howler monkeys. He's going to go broke before he fixes the problem.
That's hilarious, but it probably doesn't have a code. The car hasn't ran at all to know theres an issue. Your advise is as pointless as the ideas you complained about.
2003 GMC Sierra SLT 2500HD CC/SB |
I didn't think it would be a fuel pump. Not saying I know the issue, because i don't. Now when it runs does it miss, does it run crappy, or like a champ? When it dies is like it run worse and worse until it dies, you know gradually die quickly if that makes sense, or does it just die, like BAM It's dead, like you turned the key off. You have to be very specific and detail oriented if you wanna figure it out.
Have you checked plugs after it dies? Are they wet? Can you prime the fuel system?(hear the pump running on key on accesory) What's the batteries voltage?
battery
How bout u change the crank sensor?
#25
Fuel pump, fuel pump relay, fuel pump fuse, crank sensor...these are the likely suspects.
There's also the dme relay, starter, dme, battery. Methinks the OP is not motivated to get his car on the road...taking too long to get things fixed, such as 2 months for a water pump, and 3 months for a no start issue.... |
