E30 (1982 - 1993)
So i started to replace strut insert today at a hobby shop on base all the tools i needed were there. So after the car was lifted and i took off the wheel i tried to realse the tie rod from bottom of the strut that is connected by A weird looking nut/bolt.
{THIS IS WHERE THE PROBLEM CAME INTO PLAY} ![]() The nut that holds the tie rod and the bottom of the strut into place keeps spinnig as if the bolt/nut diddn't even get loose and the stud and threading itself is spinning inside the bushing and nut at the end tie rod. I also noticed that on top of the nut or i should say stud is a hex shaped but it looks like its stripped i couldn't get the hex wrecnh to loosen it so im really lost on what to do i believe its a self locking nut which means one time use which only cost a dollar or so but how do i get the nut off tie rod end and the bottom of the strut?????? Is there any other way to replace the strut insert without disconnecting the tie rod end??? |
To keep the tie rod end from spinning, lower the car until you can reach it with a jack. Put the jack under the tie rod end and raise it just enough to stop it from spinning. Use a 17mm socket to remove the nut. CLEAN the nut so that the socket will fully engage the flats before you go any further. Use a 6-point socket if you have one.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
+1 - spot on
Yup
