Old 09-28-2012, 11:07 AM
piyu7444 piyu7444 is offline
Mein Auto: 328i
Unhappy Gas Mileage Issue on 2008 328i Sedan
I need some help here -------> Bought brand new 328i Sedan in May of 2008 and ever since it has been a great car. I have about 48k Miles on it. I have always used gas from different gas pumps (whatever is available closest)
About a year ago I just started using COSTCO gas (yeah I know a lot of you will say that's badddddddd) but still had no issue with how the car drove or gas mileage.
Just around the expiration of warranty (May 2012) the car show'd a "check engine" light. The dealership looked into the issue and found that the sensors around the exhaust lifters (close to crank shaft) had an issue. They replaced the INTAKE CAM SENSOR as well as the EXHAUST CAM SENSOR WHEEL.
After they did this I felt an issue with the car's acceleration....... While shifting from gear 1 to 2, 2 to 3 etc I could feel a lag as if the gas is being cut out for some seconds. It felt like driving an old stick which gives you a good 'thump' between two gears.
I took it back to them and then they exchanged the sensors from one side to other which did not resolve the issue and I had to take the car back to the dealership (3rd time is a charm)
They changed the above said parts completely again and asked me to "let the car learn my driving pattern" for couple of weeks. That resolved the issue 90% (sometimes it still does it)
Now the issue for which I need help --- After this job was done the CITY GAS Mileage dropped to 14-15 (from 20) and the freeway mileage dropped to 23-24 (from 27+)
Dealership checked the car for possible error code etc and said everything is as good as it can be.........asked me to fill from Chevron..... I started using Chevron gas 100% of times but it did not help at all.
Now I have asked them to get BMW involved in this issue. The service adviser is a great guy and he is not talking to his director about finding a way to fix this issue. They will come back with some answer by Monday but I wanted to see if anyone has experience anything like this or has any advice for me?
A full tank of gas gives 200 miles in city and it sucks! My ML 350 is probably better when it comes to city driving.
HELP PLEASE !!!
"Nearly everything you do is of no importance, but it is important that you do it."
Old 09-28-2012, 11:26 AM
floydarogers's Avatar
Pedant and Curmudgeon
I wonder if the Valvetronic position motor is having problems? Or the Vanos?
Old 09-28-2012, 02:01 PM
Mein Auto: 328i
Thanks floydarogers.........
bump - anyone else?
Old 10-01-2012, 10:29 AM
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Mein Auto: 2008 335Ci
Put in a bottle of Chevron's Fuel system cleaner and use good gas, Sunoco, Shell ..... You have NO idea who's gas Costco sells.
No matter how fast I go, there's always someone slower in front of me.
You can lead a horse to water, but you can't make him jet ski.
'08 335 E92, M-Sport option, 6 sp auto w/paddle shift
JB4 PNP G5 ISO upgrade, 3" charge pipe w/dual CM5 nozzles, meth injection, Oil Catch Can. Zero to 'OH GOD!' in a scream.
CCA Member 109065
CQ ... CQ...Kilo Charlie 3 Bravo Whiskey Zulu calling CQ
Old 10-06-2012, 11:50 AM
Mein Auto: 328i
I am already using Chevron but it has not helped much.
Old 10-06-2012, 11:54 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
he means the techron fuel system cleaner.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 10-06-2012, 12:04 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
A clue.
Code[s]?
Clearer thump detail, please.
Cleaned your VANOS solenoids? Or just replace 'em. Easy DIY - at your mileage might be preventative maint.
__________________________________________________ ________________
Edit: OP's prev posts 2009 - hasn't posted here in over a week - dead thread....
Old 10-06-2012, 07:48 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Originally Posted by CALWATERBOY View Post
A clue.
Code[s]?
Are you kidding me! "Easy DIY," for who? DSX? I'm often proud of myself for finding the windshield wiper fluid refill port.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-06-2012, 08:04 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
Definitely get BMW codes through OBD II ASAP.
Old 10-06-2012, 11:01 PM
Mein Auto: 328i
Orient330iNYC - Thanks for calrifying. I will give it a try.
Saintor - I dont know much so please explain "BMW codes through OBD II ASAP"
Old 10-06-2012, 11:11 PM
Mein Auto: 328i
A clue.
Code[s]?
Thump detail - You can feel when the transmission is changing. You can feel while accelerating as if someone was holding the gear and has suddenly released it to let it move to next level. Earlier to the work done on the car the transmission was as smooth as new but not anymore. Also this will not happen ALWAYS. Its intermittent so does not bother me all the time..... BTW - The dealership called me and said they want to drive my car for 3-4 days to observe what gas mileage it really gets. Once they verify it they plan to get BMW involved.
Old 10-08-2012, 09:29 AM
Shucks P&G - nothin' to it really - buy a few tools and you're in business! $4-5K, nothin' to it.
