E34 (1989 - 1995)
Old 09-28-2012, 05:22 PM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
ATTN M60 owners!
If you haven't recently tightened you oil pump bolts, do it asap! I did mine willy nilly last year and today the pump started to smash against the lower oil pan. The noise it makes is unmistakable, it's the sound of catastrophic failure. I just did mine - again, and used blue threadlocker to keep them torqued and in their holes, rather than bouncing around on the pan.
Old 09-28-2012, 05:47 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
OUCH !!
Gald you got to it quickly. I have read about this problem before.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-29-2012, 01:37 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Anyone ow if this is an M70 issue too?
Old 09-29-2012, 04:31 PM
Costa's Avatar
Shouldn't be an M70 problem, never heard of it happening before
Old 09-29-2012, 06:09 PM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
Hey Costa,
How hard of a job is it? I need to check mine out. Do you have a part # on the gasket for the oil pan?
Sent from my SPH-M910
Old 09-29-2012, 07:25 PM
Costa's Avatar
The majority of the time you're waiting for all the oil to drain. It's a fairly simple job. Took me about 2-3 hours to do it, and I cleaned and loctite-ed all the bolts and made the pan look brand new again inside and out. These are all the part numbers you need. The other two gaskets are for the oil level sender
Old 09-29-2012, 07:37 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/94 530i
I tried to tighten mine the last time I changed my oil pan gasket, but could not for the life of me figure out what bolt(s) to tighten. Do you have any more pictures to post of your DIY?
Sent from my ADR6410LVW using Bimmer App
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - LOADED
Old 09-29-2012, 09:19 PM
Costa's Avatar
Unfortunately I didn't take any of my oil pick up/pump because it was sort of bent from banging around on the pan and I was really mad about that
Old 10-01-2012, 08:55 AM
1995i540 1995i540 is offline
Satin Black E34
Mein Auto: 1995 540I/6
You can see the bolts pretty clear.. don't simply tighten everything. Feel if anything is loose with fingers and then tighten it. You don't want to overtighten anything that touches the pump.
///////////////////////////////////////////// E34 Addicts
