blown head gasket? - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 09-28-2012, 06:52 PM
drbroad drbroad is offline
Mein Auto: 1988 325i
blown head gasket?
Current mechanic found a miss in two cylinders, lowered compression in them as well. Feels a head gasket is blown. Looking for a general second opinion from someone out there. 1988 series three 197 K mileage, uses NO oil, ran fine when I took her in for a throw out bearing and clutch pack......
Old 09-28-2012, 09:23 PM
shima14 shima14 is offline
Mein Auto: 86 325e
Are the cylinders that are low next to each other?. If so I'd say head gasket
Old 09-28-2012, 10:32 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
you took a car in to change the clutch and he did a compression test ?
why was he touching the motor to do a compression test in the first place ?
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 09-28-2012, 11:22 PM
BMWFatherFigure's Avatar
Old School
Wierd. Give some more b'grnd on why checks were done.........
Current:
E38 Parts Car
Previous:
Old 09-29-2012, 12:11 PM
downhiller's Avatar
livin large
lowered compression as in how low. psi numbers help alot
Old 09-29-2012, 01:45 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Yet another shady mechanic fishing for a job
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 09-30-2012, 12:43 AM
Appreciate the quick replies. Check ride by the mechanic revealed the 2 cylinder miss. I heard it from the garage bay when they started the car to bring to me.... the subsequent compression check revealed low readings on cylinders x 2. I will know more details on Tuesday. Not my primary ride but could be if we can get her running well. I have wanted a BMW for several years and this has been the perfect fit so far.
Old 10-01-2012, 02:20 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Thumbs down Damaging vehicle in workshop
If somebody brings a car in good running condition into a local workshop, so that they fix his clutch
& it comes back with a miss that is clearly audible..
I suppose some mechanic will be wearing a shiner for a few days
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
