Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 09-29-2012, 03:51 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
Reference - Original BMW Accessories for the E65/E66
I thought a thread was in order to show Original BMW Accessories offered for the E65 and E66. Sometimes the BMW accessory catalogs don't provide much detail. Please post part numbers and photos.
File Type: pdf Accessories catalogue 7series - 2011.pdf (4.38 MB, 247 views)
2005 745i Individual
Old 09-29-2012, 03:57 AM
Universal Rear Protective Cover
BMW Part Number: 52 30 0 414 362 Universal Rear Protective Cover
Not for vehicles with rear comfort seats (although rear electric head rests would not interfere).
- plastic lined bottom
- split 60 / 40 with a zipper
- plastic tabs keep the outside edges in place
- zipper openings for seat belts
- door covers have metal tabs attaching using elastic (I find the door panels too tight to use these metal tabs - the end result is the door covers flop around a bit when not attached)
Name:	RS Protector1.jpg
ID:	343698   Click image for larger version
Name:	RS Protector2.jpg
ID:	343699   Click image for larger version
Name:	RS Protector3.jpg
ID:	343700   Click image for larger version
Name:	RS Protector4.jpg
ID:	343701   Click image for larger version
Name:	RS Protector5.jpg
Old 09-29-2012, 04:01 AM
Fitted Luggage Compartment Mat
BMW Part Number: 51 47 0 142 390 Fitted Luggage Compartment Mat
- one piece flexible plastic
- notched back lip for those with optional ski sack
- covers entire floor pan
ID:	343703   Click image for larger version
Old 09-29-2012, 04:36 AM
First Aid Kit
BMW Part Number: 82 11 0 146 022 First Aid Kit
- included adhesive velcro fastener to attach bottom vinyl bag to tool tray
Name:	First Aid Kit1.jpg
ID:	343706   Click image for larger version
Name:	First Aid Kit2.jpg
Old 09-29-2012, 09:27 AM
Key Fob D-Ring
BMW Part Number: 51 21 6 927 692 Shackle Set
- 2 D-rings are included
- need small (jeweler size) flat head screwdriver to remove threaded pin and to tighten
Name:	Key Fob D-Ring.JPG
Old 10-21-2012, 10:13 AM
Silver Bulb conversion
BMW Part Number: 63 12 0 420 391 CONVERSION KIT, BULBS, SILVER - no longer available!
BMW had a kit to convert all your turn indicator bulbs to the "silver" version, assuming you have the white turn indicator lenses. This kit is NLA (no longer available). However the individual bulbs still can be purchased.
63-21-7-165-496 BULB SILVER, 12V 5W (ask your BMW parts counter to NOT allow this number to be superseded, otherwise you get a normal amber bulb)
63-21-7-160-897 BULB SILVER, 12V 21W
In order to install the 21W headlight turn indicator bulbs you will need the Euro socket, as the North American socket is designed for wedge style bulbs. This Euro socket has a plastic tab that prevents it from being installed in North American spec headlights. A razor blade can be used to remove the tab.
63-12-6-916-102 BULB SOCKET, TURN INDICATOR
The 21W silver bulbs are actually Philips Silver Vision PY21W bulbs with a BAU15s base, though Philips doesn't seem to distribute them in North America. Supposedly you can get the same bulb from VW (number N 102 564 04).
Name:	Silver bulbs 1.jpg
ID:	346696   Click image for larger version
Name:	Silver Bulbs 2.jpg
ID:	346697   Click image for larger version
Name:	Silver Bulbs 3.jpg
ID:	346700   Click image for larger version
Name:	Silver Bulbs 4.jpg
ID:	346701   Click image for larger version
Name:	Silver Bulbs 5.jpg
Old 12-08-2012, 01:41 PM
Oil Filter Cover for reinforcement plate
BMW Part Number: 51 71 7 141 464 COVER, REINFORCEMENT PLATE
(This isn't really an accessory, but I find it usefull...)
- reduces debris on oil filter housing
- improves airflow over reinforcement plate?
Name:	Reinforcement Plate Cover1.jpg
ID:	352373   Click image for larger version
Name:	Reinforcement Plate Cover2.jpg
ID:	352374   Click image for larger version
Name:	Reinforcement Plate Cover3.jpg
HTML code is Off
