Engine died going around corner - Bimmerfest - BMW Forums
Old 09-29-2012, 02:36 PM
jsanders jsanders is offline
Mein Auto: 750iL
Coming downhill then turning onto my street, the engine died and wouldn't allow me to restart for a good minute or so. All the while sitting in the middle of the intersection. Gas tank was half full. An error message popped up for a few seconds that said something about "Anti-Roll" and "Curves" then went out. A lot going on while facing oncoming traffic, car wouldn't start and trying to read the dash! Car is running fine now, but worried that the next time my wife may be driving. Took to dealer and they want $150 (non-refundable) to diagnose because no faults were found. Thoughts?
Old 09-29-2012, 05:12 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i
Lose battery connection?
Old 09-29-2012, 06:46 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Smart idea is to read errors from CAS and other modules
Old 09-29-2012, 07:20 PM
Slick444 Slick444 is offline
Banned
Mein Auto: 750
Did your car say dynamic active control inactive ?
Old 09-29-2012, 09:50 PM
dingxhng dingxhng is offline
Mein Auto: 2008 750Li
go search for Integrated Power Supply Module in the forum. $120 if DIY.
Old 09-29-2012, 10:24 PM
wayne86 wayne86 is offline
Banned
Mein Auto: 7 series, '08
there used to be problems on earlier BMWs with the gas pump and sumps in turns. those issues were with 1/4 tank or less.
Old 09-30-2012, 11:53 AM
ndabunka's Avatar
ndabunka ndabunka is offline
'12 X5 35d Black-on-Black
Mein Auto: X5d Ski Machine-Blk Betty
There are other KNOWN issues related to the suspension that throws a code and usually puts the car in "limp mode". Looks like yours simply skipped that "meddlesome" intermediary step. Try searching on active suspension or other similar words.
'12 X5d Sapphire/Black/Bamboo, Sport (ZAP), Premium (ZPP) & Premium Sound(ZPS) packages: 20" 214's, OEM Hitch
Old 09-30-2012, 01:36 PM
Mein Auto: 750iL
The error message said something about anti=roll or something around curves but was only on few a couple of seconds. Once the car started and did a check everything was ok, according to the car.
Old 10-02-2012, 01:13 PM
chrisrees chrisrees is offline
Mein Auto: 02 745li
I had that and one other message. Wouldn't start after several attempts to start. Took it in codes said faulty crank shaft position sensor. $380.00.
Repairs 2012
wishbone & steering rack
Rfmd hydro steering gea
combination nu
Ball Joint
Tension strut with hydr
Switch unit steering column
Coils 5&7 and new spark plugs
Faulty DSC Control Module
Fuel Gauge
Leaking Crank Case Vent Valves
Power Steering pump, washer pump and grommont,
Crank Shaft position sensor
Total $13,481.37 in one year my mechanic swears all these parts are re engineered to work better than the originals lol
Old 10-03-2012, 02:26 AM
Mein Auto: 750iL
Car still running fine since. Did check all fluids, especially steering and suspension reservoir; was a little low. Oil was a quart low. Took it back to dealer since it was just recently serviced and made sure ALL fluids were "topped off" and all good...so far!
Old 10-03-2012, 05:53 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Your signature scare me
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 10-03-2012, 01:49 PM
Mein Auto: 02 745li
LOL its awesome! The car is such a lemon, however I refuse to sell it. It is covered by warranty through 2016 and I refuse to walk away from an actual warranty I for once get to use
Repairs 2012
combination nu
Ball Joint
Fuel Gauge
