E60 (2004 - 2010)
Old 09-29-2012, 05:36 PM
Sharif5 Sharif5 is offline
Mein Auto: Bmw 5 series
Car starts only on reverse
I have encountered a problem all of a sudden, I have a 2008 525d manual and after coming to a stop I tried to turn on the car by pressing in the clutch but the engine tried turning them died and every time I tried starting it all I hear is a tick noise. As my car could only be pushed back at the time I tried to jump start it in reverse but as I put it in reverse gear and pressed the ignition it started up perfectly fine. I thought it was a minor setback but now it happens all the time and it only starts up when I put the car lever in reverse whilst pressing in the clutch. Has something happened for this to happen? Any help will be much appreciated. Thanking you in advance
Old 09-30-2012, 07:16 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
The Neutral Safety Switch in or on the transmission needs to be adjusted.
Old 09-30-2012, 07:33 AM
Could I do it myself or would it require serious labour where a professional should get to it to adjust?
