Old 09-29-2012, 05:48 PM
jorden1965 jorden1965 is offline
Mein Auto: 2009 750i
grille and steering wheel update
had my 2009 750I in to finally have the active stabilizer bar replaced. that persistent bock/ knock noise from the front end is GONE! My dealer gave me a brand new 750LI as a loaner (1800 miles)! I much preferred the thicker steering wheel and the grille from the 2012. Are they interchangeable? Does anyone have a source for steering wheels?
Old 09-29-2012, 08:29 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
I'm having my current grille replaced w with the grille on the 2013 model on Friday. I had a chance to check out a 2013 and the grille is different and looks nicer for some reason. Now you mentioned you got a 2012 loaner, the 2012 didn't have a difference between the grilles. The only different grilles was the stock grille vs. the grille for the night vision package. And did the 2012 have the m package because the m package cars have a thicker steering wheel.
I know the grille is changeable, the steering wheel I'm not too sure about. Check out http://www.realoem.com/bmw/select.do, get the part numbers and visit http://www.schmiedmann.com, input the part number and you'll get pricing.
2011 750i
Old 10-01-2012, 09:59 PM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
Someone on the forum a while back had his regular steering wheel replaced with an individual w/ wood trim. Stands out in my mind because I remember it being somewhat expensive since I believe the airbag module had to be replaced too. I think it was LovinM6?
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 10-02-2012, 05:50 PM
Heads up for anyone looking to swap grilles for the 2013 grille. The part #'s for the 2013 grilles on realoem.com are incorrect; the part #'s showing up for the 2013 are actually 2012 grilles and as of right now the 2013 grilles are not available to order.
2011 750i
