Go Back   Bimmerfest - BMW Forums > Bimmerfest Regional > Regional Forums > Great Lakes Region - IL, IN, MI, MN, OH, and WI
Regional forum for members in IL, IN, MI, MN, OH, and WI.
Old 05-08-2013, 01:35 AM
cjenke cjenke is online now
Mein Auto: 528i
new here and need help '01 540i
Hello, im new to this message board, my name is jenke.
I have a 2001 540i auto that Ijust had an engine installed in. The previous engine had low compression on 2 cylinders and was told it needed to be replaced. After inxtalling the new (used) engine it wont start! It cranks over but I am not seeing power at the fuel pump. The mechanic also said it has no spark. I replaced the cam and crank position sensor and checked all the fuses. The car comes close to starting when I spray starting fluid in the throttle body.
Any one that can help with either advice, suggestions or actually come work on the car? Im near minneapolis and woukd greatly appreciate it!
Thanks Jenke
Old 05-08-2013, 11:32 AM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
Re: new here and need help '01 540i
You may get some response if you post this question on the E60 section.
Old 05-08-2013, 05:20 PM
Mein Auto: 528i
Any help please
