Old 09-29-2012, 11:37 PM
lll F10 lll lll F10 lll is offline
Euro ****
Mein Auto: 2012 535i M-Sport
N55 Intake Idea
Anyone have thoughts on doing this for an N55? Im so tempted to try it...so..so.. tempted. But as far as I know the N55 much more sensitive to all changes on the cold side compared to the N54 correct? Input please. Thanks!
http://www.e90post.com/forums/showthread.php?t=349293
http://www.e90post.com/forums/showthread.php?t=549854
http://www.e90post.com/forums/showthread.php?t=333538
Old 09-30-2012, 05:26 AM
Gypsy550i Gypsy550i is offline
Mein Auto: 2012 BMW 550i M Sport
if that works for a F10 550i i will do it with you lol
Old 09-30-2012, 08:40 AM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2007 MDX
1. Why would the N55 be more sensitive to changes on the cold side? And what do you even mean by that?
2. These types of intakes are only beneficial if your turbo is causing negative pressure in the pre-turbo intake while boosting. To see if this will have an effect, you need to do some manometer testing on the intake along several points. Otherwise, all you're doing is marginally cooling down the intake air and letting more sound out.
This setup is actually pretty stupid. There is no need to add a filter on the end of the secondary intake hose. In fact, you're defeating the purpose of this hose. The hose should ideally face forward in the front of the valence with a scoop to collect air while driving. The idea is to pressurize the airbox with as much air as possible to prevent negative pressure. Adding a filter here is redundant and counter to the original purpose.
Here is a better setup. This was from my Volvo days. Not my pics, but I had a similar setup. Another engineer and I did extensive testing to see gains. Even running a tune with 21 psi of boost, it was less than you would think.
2011 535i
Sophisto Grau / Oyster - Black Nappa, Anthracite Wood Gone but not forgotten.
Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss.
Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians
Old 09-30-2012, 05:50 PM
Euro ****
^ I believe the issue is MAP vs MAF.
Also, I know what you mean in terms of the filter bring redundant but I guess it was for the purpose of filtration. You're increasing air intake but retaining the same amount of filtration, so I supposed the guy who made it figured why not stick a filter on it as well. In California, we've been hitting high 90's-100's consistently. Considering it costs less than $30 in materials(if not including the cone filter), I wouldn't mind doing it.
Old 09-30-2012, 08:16 PM
so the question is....is there anyone in vegas that could do this? And does it have a sound difference
Old 02-20-2014, 01:40 PM
Don Juan's Avatar
Don Juan Don Juan is offline
Mein Auto: 2013 535i M-Sport
Actually is not redundant . Take a look of the N54 intake. The side where Mr5 attached the hose is the side of where the clean air goes into the Turbos (after the drop in filter) . If he did not add the 2nd filter in the new hose, dirt, debris and whatever elsel will get into the Turbos. The whole idea here is to provide a 2nd source of air to the factory intake. The BMS DCI and Cold air intakes will heat soak rapidly in warm weather areas, defeating the purpose. You could add an intercooler and may help some.
So the idea is great but not sure if I would cut into my airbox. Instead more interested in doing air scoops... anyone ?
2016 X5 Mineral White/Terra Dakota Leather M-Sport.O Prof Nav.Muticountor Seats,Rear Shades, 20"Msport wheels.Coded
2016 I3 Fluid Black/ Deka World dark cloth interior with signature blue accents .Prof Nav,Rear Camera, 20"wheels.Coded
Old 02-21-2014, 07:38 AM
hufington's Avatar
hufington hufington is offline
HUFINGTON
Mein Auto: '16 BMW 550xi F10
Why don't you try the Burger Tuning cold air intake?
http://burgertuning.com/N55_BMW_Performance_intake.html
16 BMW F10 550xi - 4.4 L 330 kW (445 hp) Fully Loaded w/ ZLL,ZCW,ZDH,ZLP,XDB,ZEC,ZLS,2TB,0456,S6UKA,6NS[/COLOR]
13 BMW F10 535i RWD - 3.0 L 221 kW
07 BMW E64 630i - 3.0 L 200 kW
03 BMW E65 745i - 4.4 L V8, 242 kW
98 BMW E39 535i - 3.5 L 183 kW
95 BMW E34 540i - 4.0 L V8 210 kW
89 BMW E30 M3 147 kW
17 MB C217 S550 4MATIC Coupe
15 MB W222 S550 4MATIC
10 Infiniti G37x Sedan
09 Mercedes C 350
08 Infiniti G35x Sedan
04 Mercedes CLK 350
01 Mercedes C 230
Old 02-21-2014, 10:02 AM
Don Juan's Avatar
The bms is nice but not good for my location. Too hot and it will get heat soaked with the standard intercooler. As soon as the car starts getting hot it starts to minimize any gains. The method above avoids that plus it provides another nostril ( for lack of better words) to suck more cold air.
