E36 (1991 - 1999)
Old 09-30-2012, 07:35 AM
Echo46 Echo46 is offline
Mein Auto: 2006ZCP M3and 1999 M3vert
Front Struts Rear Shocks Mounts All Replaced
All
Friday and part of Saturday was spent changing struts and shocks, including mounts, on my 1995 e36 Montreal Blau vert. I replaced the original equipment with Bilstein Touring. While this is not a very difficult DIY, it does get a little tricky dealing with compressing the springs and making sure the new struts are built perfectly. Also wresting the struts back in was a bit of a pain in the ass.
Anyway, when removed both shocks in the rear they were both completely blown at 95,000 miles. I know, I know they should have been replaced at 50,000 but I only bought her at 87,000 miles. The prior owner was a complete animal when it came to maintenance but luckily he kept it garaged and did not abuse her. Rear shocks and new mounts went in easy and quick.
Again when I pulled the front struts they were completely blown with zero rebound. One had shock oil all over it. As I said the only tricky part is spring compression. Don't even try to compress the springs and remove the rusty bolts without a good air impact wrench. Made this job easy. strut replacement took me about two hours each side as I went nice and slow asit was my first time doing this job.
Much better ride with the new shocks.
Old 09-30-2012, 09:13 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Excellent! Glad you got everything in. I bet you're looking for excuses to go for a drive, now.
1998 BMW 328is
1966 Pontiac GTO
Old 09-30-2012, 03:40 PM
Indeed, I just drove out to Greenport, almost the end of Long Island. It was about a 100 mile round trip with some spirited driving to put the new suspension through it's paces. Feels a bit tighter and much stiffer over bumps and dips in the road. Very happy with the results. Next up is the control arms, CABS and RTABS.
By the way, I visited the Greenport Brewery Tasting room and sampled some incredible beer. The Gobsmacked IPA and Leaf Pile Ale were off the hook.
Old 10-02-2012, 07:10 AM
So, I'm out driving around yesterday and I'm hearing a pop sound from the left strut. Im thinking that i messed something up either when I assembled the strut or when I installed. It only happened twice but it really bothered me. I really wasn't feeling taking the strut off, compressing the springs and disassembling the damn thing again.
By the way, I consider myself a half decent home mechanic and am willing to tackle any job. I take my time and am very fastidious. Well, I'm not so sure how good I am. I was racking my brain as to why it would pop. Spring not seated correctly? Blown strut already? Broken spring? Top bolt not tight enough? Worn end links? Worn out control arm? Worn out CABs? Steering rack issues?
So then I remember that sometimes if the lugs are loose you will hear a pop every once in a while. Well guess what, me, Mr Mechanic, forgot to tighten the front wheel lugs completely after I lowered the car. What an idiot.
Old 10-02-2012, 08:17 AM
hornhospital's Avatar
D'oh, You Kids!
Been there. Glad you found it before serious damage was done.
Sent from my MB860 using Bimmer App
Quotes to live by:
Old 10-02-2012, 04:54 PM
kode302 kode302 is offline
Mein Auto: 1998 328is
Same happened to me, unfortunately it cost me a new hub assembly. Good thing you caught it in time.
[B]Member of the Non-M Bumper by Choice Club[/B
Old 10-02-2012, 05:23 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
If you'd ignored the noise until the wheel came off and damaged your bodywork, then you'd be an idiot. So far you've only achieved a score of forgetful.................
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 10-02-2012, 05:53 PM
I guess I was so excited to get the wheels on the ground and out on the road I just forgot. It is funny the sounds these cars make and the clues they provide to determine and fix problems.
