The X5 SAV Forum
Old 10-03-2012, 09:38 PM
SexyBeast4.8 SexyBeast4.8 is offline
Mein Auto: X5
No hissing & leaking
My X5 is leaning lower on one side (driver side) & higher on the other. I'm requesting help with solving this problem. I checked all fuses and they're fine. The drive isn't affected in any way (to my knowledge), but the leaning part is crazy. Can anyone help me with this problem? I attached photos of what it looks like & any advice is greatly appreciated.
Old 10-04-2012, 09:53 AM
ChezWhiz ChezWhiz is offline
Send a message via AIM to ChezWhiz Send a message via MSN to ChezWhiz Send a message via Yahoo to ChezWhiz
Mein Auto: 2001 X5 4.4i
Same thing happened to my '01 4.4i. In my case, it turned out to be a leak in one of the air bags used in the air suspension. However, there's also a known issue with loose connections to some of the air suspension components (located under the spare tire). If you want to check that first, take a look at the DIY article on XOutpost dot com: http://www.xoutpost.com/file-x5tips.htm
Colby,
[Dead] 2001 X5 4.4i w/ 139K miles (probable cracked engine block)
2005 X5 4.4i w/ 97K miles
