Old 04-20-2014, 05:17 PM
grnman grnman is offline
Mein Auto: e39 540i
97 540i will not start
Hi,
I love the forum, it has helped me no end in the past but.... I have not found anything similar to this...
190k miles, new battery in December 2013.
About a month ago, the car would not re start after a short journey, turned the key and everything went dark, no lights, no power to anything. Jump started fine, I charged the battery and all went well for about a month.
I went to start the car at home and again all went dark, no turn of the starter motor, just all dark, no lights panel or otherwise, just dead. I applied power to the terminals under the hood to "reset" the system and allow me access to the battery compartment.
The battery showed 12.4 volt on the multimeter across the battery terminals, but, no joy again. It would seem that if I fully charge the battery I can get a random number of normal starts, then nothing.
Any ideas?
Thanks.
Old 04-21-2014, 12:13 AM
soupiemelody soupiemelody is offline
Mein Auto: 1990 325I 1998 540i/6
alternator not charging
Old 04-21-2014, 10:25 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
You should get 14V+ with the engine running at 1500 RPM. Sounds like the alt is not working.
Old 04-21-2014, 08:23 PM
Mein Auto: e39 540i
Thanks, I shall see if I can get it started tomorrow and check the voltage again.
Old 04-21-2014, 09:25 PM
Beemergirlie Beemergirlie is offline
Mein Auto: 1998 BMW 540i 6sp manual
When this happened to me? It was far more ominous! I had everything checked.. Alternator, battery, etc... Turns out my ignition was failing... Eventually my key started to spin freely in its housing to my horror. When I drove it to the shop? It wouldn't even turn the engine off, and I had to step on the brake and stall it to kill the engine.. Something heartbreaking to do to my baby.. I had to wait for over a week while my mechanic LITERALLY SENT MY PROOF OF OWNERSHIP TO BMW and wait for BMW to send me back a factory ignition matching my keys! $1,000.00 later? I was back on the road!
Good luck! Hope it isn't as bad as mine was.. What a freak thing to fail!
Old 04-21-2014, 09:27 PM
I think there was a sensor they had to replace too, in the steering column somewhere... If I'm not mistaken? That alone may cause it not to start.. But I could I be wrong, I paid to have it fixed, so I am relying on memory only
Old 04-22-2014, 12:41 AM
Didn't the invoice give details? I would expect that for $1000!
Old 09-24-2014, 03:49 PM
Mein Auto: e39 540i
More info...
Sorry to hear of your woes Beemergirlie; it has been a while but, here is my update: the alternator is putting out 14+ volts. This seems to happen when the car has been standing for a few days. The battery seems to settle around 12.2v, is this enough??? The shop that I got the battery from says the battery is good.... The randomness of the the fault is most annoying.
I hope I do not have the same issues as Beemergirlie, I think it would move it into the uneconomical repair bracket if that is the case.... Any other ideas/suggestions would be most welcome.
Old 09-24-2014, 05:51 PM
SSJRICH 540i's Avatar
SSJRICH 540i SSJRICH 540i is offline
2000 M5
Mein Auto: '00 M5
Check the ground connection to the battery and to the frame. I once had a similar problem with the old e39 and I had a loose ground connection to the battery.
If you have checked out all the suggested things, I would have a shop check it out. You may have a similar problem with either your ignition switch or your ignition cylinder.
Current - '00 M5 - '02 530i M sport - '02 X5 4.4i Sport - Old - 00 540i/6 M sport -Old - 97 540i/6
Old 09-24-2014, 08:39 PM
12.2 V means that the battery is only 50% charged. Get it load-tested.
