Old 09-30-2012, 09:16 PM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
Auto Headlights always on
YES I Searched! LOL. Did not come up with anything. Even tried google. Is it normal for the lo-beams (HID'S) to be on when I have the switch in Auto and it's sunny as could be down here in FL during the day? Or is this "daylight running lights"? 2ndly how do you dis-able DRL's?
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 09-30-2012, 09:44 PM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
Your fog lights are on lol. my lights are on at all times the car is on, if you put them on auto and your fog switch is on they will be on. turn off the for switch then they will be auto.
Old 10-01-2012, 12:25 AM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
not sure why your low beams always stay on but just dont keep it on auto and for the DRL you will need the dealer to take it off or find someone with inpa/isoft and have them reprogram it.
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 10-01-2012, 06:21 AM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
Originally Posted by MikesE39 View Post
Your fog lights are on.
^This
Old 10-01-2012, 07:10 AM
Fog lights are on... Why doesn't the owner's manual cover this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I actually looked up and read it. Thank you guys. DRL's are fine then. Thank you!
Old 10-01-2012, 09:41 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
If it does cover everything you need to know about your E39, then who need Bimmerfest?
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 10-01-2012, 10:33 AM
^exactly. I'm glad it's not a sensor or something.
Old 10-01-2012, 05:44 PM
Well, leaving work today, sunny as hell in FL. had the fogs off, Headlight switch in auto. Lo beams were on. If I turn the lights off, I have NO DRL's. Not sure what's going on. Is the light sensor on the dash or up by the rearview mirror? Driving me nuts.
Old 10-01-2012, 06:33 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Both - on the dash and in the rearview mirror.
Only way to find out is to hook up the GT1. It will give you a quick diagnostic. Not the fix. Maybe one sensor is not working, and the other one thinks it's dark. As a result, it gives the command to turn on the lights.
Old 10-01-2012, 06:40 PM
damn it. I'm betting one or both are bad.
Edit- They work fine. I guess it wasn't sunny enought the other evening....
Old 10-27-2012, 09:15 PM
FUQTodd FUQTodd is offline
FUQTodd
Mein Auto: 1998 540 DINAN/1997 528i
In the GM products (up to 2004 or 5 is what I tried) the daytime running lights go out when the ebrake is applied - hence barely make the switch and the lights may go out with the handle on the first click. Just make sure it's not dragging. Might work....
The world loves intellect, yet despises the intellectual.
