Coolant Level Sensor performance - Bimmerfest - BMW Forums
Old 10-01-2012, 06:23 AM
mr magoo's Avatar
mr magoo mr magoo is offline
Mein Auto: 2000 528i
The seam on my 2000 528i radiator let go on my way home from work Fri nite. I saw slight steam but by temp sensor read normal until 1/2 mile from home and moved quickly to red as I shut it off in my driveway. I saw no low coolant warning. I will replace the level sensor in the expansion tank as part of the upcoming overhaul, but my question is this: If the sensor is faulty, shouldn't I get a warning?
Thanks for looking and sharing any experience, fact or opinion.
Also, I am buying many overhaul parts today and am near info paralysis after reading Bluebee's compilations of analysis. They are a golden treasure, but formidable to us amateurs. (Thank you, Bluebee.), but please feel free to throw in any additional cooling sys rehab advise.
Mike
Old 10-01-2012, 07:07 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
there is no coolant light on year 2000
there is in icon on the dash panel but it is not functional. I have the same year car and have done extensive research on that issue. There is no sensor in the expansion tank, only a float with nothing attached to it. only electronic warning is on the temp gauge that car has overheated.
Old 10-01-2012, 07:22 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
Cars with the Low OBC don't get the low coolant level indication.
You can retrofit the low coolant sensor and splice it into the washer fluid level sensor wiring, takes about 45 minutes. Now you'll get the low washer fluid light when coolant or washer fluid are low.
Old 10-01-2012, 07:27 AM
mr magoo's Avatar
Thank you
Thank you for your replies and the WW level trick. Maybe someone has done a DIY. I will search
Old 10-01-2012, 09:30 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
"Oh Mr Magoo, you've done it again!! "
The coolant level sensor on the bottom of your expansion tank could be the culprit, or... the sliding floater inside the tank itself could have been stuck in a high position. Apparently the sensor uses a magnet to measure the location of the floater. If the floater is stuck, I'm not sure you can do anything about it other than buy a new exp. tank. Go genuine BMW if you do. Discounting S&H, the cost of getting one from the dealer is not going to be much "worse."
Old 10-01-2012, 09:39 AM
ndz ndz is offline
Mein Auto: 00 528i/5, 99 540iT
This was my understanding. I don't think my 2000 528i/5 w/ low OBC has a coolant level sensor.
99 540iT - Merlot Truckster
00 528i/5 - Grüen Arrow
93 740i - Grün Hornet (sold)
00 740iL (R.I.P.)
Old 10-01-2012, 10:56 AM
Really? No coolant level sensor on a model-year 2000 e39? No sensor plugged into the bottom of the expansion tank?
