Old 10-13-2012, 05:34 AM
Clif Shifflett Clif Shifflett is offline
Mein Auto: 1998 BMW Z3
98 z3 convertable
98 Z3 convertable with a bad vibration only at 70 and above. Vibration is only apparent when looking into the rear view mirror and seat. Steering wheel is smooth. Wheels have been balanced twice and a front end alignment @ a BMW shop. Also new KYB shocks front and rear. Wheels are aftermarket.
Any thoughts?
Clif
Old 10-13-2012, 01:46 PM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
Clif, how quiet is it in the car? I mean do you hear a rumbling or something that sounds like to much tire noise? I thought mine was tires, then I started getting a ratcheting sound at certain times when I got into the gas. Come to find out it was the u-joint in the driveshaft right behind the carrier bearing. Once changed, the car was super quiet and rolled a lot smoother, no vibrations, etc. Just thought I'd share "just in case". Good luck.
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
Old 10-15-2012, 05:38 AM
ALM168 ALM168 is offline
Mein Auto: Z3, e46, Ford Explorer
SMAY964,
I am also hearing a noise at higher speeds (with the cooler weather,now noticeable with the top up). I thought that it was the diff, but I do not get the normal change of sound when going around corners indicating a problem, so you got me thinking that it could be the U joint. I was planning on the changing the diff oil before winter so I will look at the U joint while the car is up on the jack stands.
Al
98 Z3, 2.8L, 43K miles
Old 10-15-2012, 08:04 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
loose mirror.
Old 10-16-2012, 04:51 AM
Not sure what you mean. The whole mirror assembly, or just the glass? I doubt that this is the problem as the noise seems to be coming from behind me. BTW - There is no vibration, just noise.
Al
Old 10-16-2012, 06:50 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
My car has always (at least for the last 5 years) made a whirring sound on deceleration. I'm sure it's something to do with the driveline, but it's not bad enough to warrant changing anything yet.
1999 528iA
2000 Z3 2.3
2003 M5
